Vauxhall front brake upgrade 256mm discs
Submitted with thanks by satans_creation.
You will notice that the discs are not substantially bigger making it easier to fit your wheels as 280mm conversion usually requires new alloys. The calipers however are much larger than the original golf ones so will make stopping much better
First of all you will need a pair of Calibra calipers and discs
There are different variations so make sure the car is 1990-1994. Others may fit but the only ones I know that almost bolt straight on are these.
They will look like this
Lucky for my me the person who sold me the discs and calipers had already made up some stainless sleeves to allow the bolts to fit. The diameter of the hole on the vauxhall caliper is larger than the golf ones hence why the sleeves are needed.
If you need precise measurements from these to make them up yourself or have the make reply to this post and I will take one back off to measure.
When bolting the calipers on you will notice the bolts off the mk1 calipers are too short, they need to be an extra 20mm longer.
To keep with the originality of the car and so you don't end up cutting the hose brackets on the inner wing trying to fit the vauxhall lines. Get front brake hoses for a vw lupo 1999-2005. I believe the front hoses from the passat 1988-2000 are the same, along with polo mk4, part numbers 6N0611701B and 8E0611775C
They don't fit 100% but you just need grind off the little lugs which hold the line in place of the later VW's
Bleed the brakes and your done!
There are no pages beneath this page
Submitted by ManicGTI
It's probably worth noting that there is a load more info on this conversion in the FAQ section:
http://vwgolfmk1.org.uk/forum/index.php?page=forumview&id=braking-faq_2
- Sleeves are not required if you use correctly sized shoulder bolts. The Vauxhall carriers use a M12 bolt, the VW 10mm. The bolts required are M12x25 Cap head shoulder bolts, high tensile 12.9 spec,
- The GM 16V calipers/carriers are available from most of the 2.0l 16V Vauxhalls of the late 80's/90's including Cavalier, Vectra, Calibra and Astra. Likely others as well.
Dave
Dave
Submitted by Eddygor
You can get the bolts here if needs be. Save making up sleeves
Mk1 Golf Vauxhall Caliper Conversion Bolts
