Project "little monster"
The point of no return - the right engine mount has been cut off, to make space for the VR6 which will take up different engine mounts
The engine crane takes the strain of the VR6 + gearbox
Can you make an insurance claim if you drive into your own car's engine?
Up and over, not too much hassles with a big engine crane
Took a fair amount of wiggling round the sides, but its in.
As can be seen, its not quite sitting at its final position - its tilted forwards. I have a trolley jack under the gearbox to play around with positions, but the first critical positioning will be gained from fitting will be the driveshafts. Since the differential on the VR6 is wider than the original, I can't use the old driveshafts as it is, also I need to upgrade to 100mm flanges. So, a bit of shopping for some cabby driveshafts will be done.
Then I'll need to shorten one or both of them, I think I'll shorten the left one, so that I get as much clearance between engine and chassis as possible.
Once that's done, I can bolt it in again with the driveshafts attached, then make a template for the left rear engine mount. I'll probably design something with loads of adjustment range in it. Then knowing the relative dimensions, I can also fabricate the right rear mount. Once positioned like this, the front mount should be relatively easy.
weldone
Web Team
Anyway, I'm now at the stage of sorting out the driveshafts. The VR6's gearbox is 10mm wider at the flanges, so this means I'd need to shorten one of the driveshafts; and also fit 100mm flanges. I am wondering, are 02A gearboxes also 10mm wider at the flanges and if so, what do people typically do about shortening the driveshafts? Is there an off-the-shelf one which fits?
chris_VW_1987 said
i would sooooo pay somone to do this …
How much money do you have? And could you honestly afford it…and the extra insurance, etc.???
will get it done then !
it should be crazy fast !
chris_VW_1987 said
wow … like overall ? … how much does this cost ?
Don't know, but I'm keeping track of all the costs. I have the costs so far, and an idea of the larger cost items coming up.
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
i reeaaaaaaaallly cant imagine what that BEAST of a engine will be like in a mk1 go kart ….
would be well worth the money
bbsmk1 said
thats what i wanted to do have to think of something else now!
http://cgi.ebay.co.uk/…eName=STRK:MEWA:IT&ih=019
8O 8O 8O 8O
Mk1 clutch pedal on left, VR6 on right. Note its bracket
5 mins later, with a grinder…
All ready to weld
Welded
Cleaned up welds with a wire brush
Sprayed in primer. I'll paint it black tomorrow.
