20vt mk1
20vt mk1
MissMk1 said
wot if u wanna 4wd it??!
depends on what its going to be used for if its everyday driving k03 is fine if your looking to build a 1/4 mile monster then k04
even with a k03 you will have a 14second car and that is a very quick car to have on the road
4wd is ok if your going to do the 1/4 mile if not then probally a waste of time and effort and trust me it aint going to be an easy conversion very very expensive to :wink:
4WD adds a lot of weight and there's an awful lot of components you're going to have to replace, or shuffle around at the back. By all means, if you want the technical challenge, go ahead with 4WD.
Another thing worth bearing in mind is the synchro system used on R32 Golfs, Synchro VWs, Audi A3 and TT, isn't technically a true permanent 4WD system, in that it has a Haldex coupling between the front and rear axles. It is effectively a 2WD until the system detects slip at the front wheels, when it engages the 4WD.
i drive around in a mini most the time then jump in the cab and try and mount kurbs with the torque steer
i'm still thinkin k04, am i mad
btw its not going to be an everyday car. it'll be my weekend car, aswell as my cabby. i must really be mad lol
but yeh thanks guys! you've given me something to think about
I saw a crinkly peanut tomorrow
will post pics of them all polished up tomorow
bens_cab said
well if u spoon it in as well a you wrap yourself round a pole you should be ok lol
I checked out the links. Then did a little more research of my own. About 2 hours later, I can conclude this is the best I've found so far:
http://www.youtube.com…5llw&mode=related&search=
(Moderators, its not rude or anything, honest. Its classy) She seems very good at it; I'd say also has a gymnastic background.
but the kids toys put you off
foxymk1 said
WOW
Didn't notice the kids toys, the first 30 times I watched it. Hang on, I'll just check and have another look.
looks like we both do the same research lmfao
ms loom is ?50 then it depends on the plugs or the cost of a pair of deep pocket jeans for the scrappy
between ?50 and ?70 ill try and make it cheap as possible as its for a fellow dubber
if it works out to be easy to install then ill knock up a couple more :wink:
whats QPE's website??? im guna order me a downpipe!!foxymk1 said
hows the plug and play coming? and how much?
going to order the pown pipe from QPE tomorow so mite need the kit soon
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
*takes pole down in a fit of rage*
cow
(i'll be able to do all that soon anyway so there!)
