rusted inner wing and rear arches!! (pics!!)
here are some more rust i've found… the drivers side inner arch doesnt have any holes, but the top rail part has started to corrode near the skuttle you can just brake it off with yours hands!
and theres some rust starting to show above the rear strut..
:dontknow:
im thinking this is too much work for me!
1272 driver with a magic tree!!
its looking like it will need a new front panal too.. :cry:
Guest user
Mark
Regards Volkswarren
On another note - I think this thread show's the true nature/spirit of this website/forum, in that all you guys in the know are doing your best to help a guy out in a sticky situation and even offering to lend some welding gear to boot!
You should all feel proud.
Alright, enough of the soppy stuff, get the angle grinder out and let sparks fly.
Lhasa Green Mk1 GTI 1.8
Secretary
The inner wings were about the only good panels on my car, probably because it had the plastic inner arches.
The panels aint expensive and the welding doesn't take long to get the hang of, just make sure that the metal is clean :wink:
Rich
well i think im gonna give this ago so i think this should get moved to the restoration section 8O
paul i REALLY appriciate that! and if you being serious then i'll really like to give it ago…and i'll refil the bottle for you…if thats possible??
so heres n update
finding all this rust and with paul telling me where to look, i decided it would be best to rip out the interior and see if the floors are ok…so thats what i did..
rat style
Doesnt seem to be any more rust on the car just mainly the front end, duno what im gonna do about those top inner wing rails tho!?
PM me and we'll sort out a date to get the stuff over to you, I'm guessing weekend is best because it gives me time to get over to yours, then 'set you off' on practising welding etc. I'll have to look into how I arrange refills, its not quite due one so there's no point doing it now. Basically, you go into a BOC place and you have to unscrew the regulator and fit it to the exchange bottle.
It came with 19kg of gas, read 250psi, now it reads 45psi. That's 3.4kg left, maybe it would be enough to do the areas you need to do? Then do a refill??? Any welding experts out there??
Secretary
In relation to the gas I can't help you. However I use the CO2 pub gas, which works just the same and works out a hell of a lot cheaper. You just need to get hold of a bottle form your local and the regulator to fit it.
Good luck with the welding the car looks in not too bad shape. Are the chassis legs under ther rear end okay?
:wink:
Definitely enough IMO - I was welding right down to less than 5psi, and it welded fine.
Just keep an eye on the gauge which governs the output pressure at the welder tip - as long as that's steady you'll be fine.
HTH
Rich
P.S. lowmk1 I did the same thing to mine - your interior looks pretty solid :wink:
In 5-10 years time, people will be doing this routinely to mk1's.
Real golfers don't play with clubs
