Pass the angle grinder - lots of pics
You'll need a reasonable quality flaring tool to do a decent job, and its probably only worth investing if you see yourself doing this on several cars.
Let us know how you get on Mark - I have this job to do (have the replacement lines already) but I never seem to get round to doing it!!!!
Chris
i would say the flaring was the simplest part of it! just took time getting nice bends in the pipe and two people is good for holding it all in place before final tightening up!
1983 1100 C
1983 1100 C
Been wearing 3 pairs of socks and 4 jumpers to keep warm, trousers help as well
1983 1100 C
1983 1100 C
Long live Mk1's! :mrgreen:
Inner arch looking forward - all primed, painted, stonechipped and painted again
Inner arch
Inner arch looking back
Sorry mess of rusty brackets - pump basket was just rust 8O
Cleaned up all the brackets with an angle grinder and wire brush then painted with Hammerite. Fitted new mounts and stainless steel nuts/washers.
1983 1100 C
1983 1100 C
That pump bracketry is looking superb as well - its amazing how well some of the original parts come up after a good clean and repaint and plenty of elbow grease.
Its almost enough to motivate me to get out into my garage even in this freezing cold!!!!
Chris
The arches were zinc primed, sprayed with alpine white, sprayed with stonechip and in the latest photos have just been painted with alpine white again. As the stone chip leaves such a rough finish I brushed the final alpine white coat on. Got half tin left over from spraying with a compressor which I thinned by about 30%, good finish even with a brush.
I did get an aerosol of alpine white for the outer arch, filler neck area and the qulaity is amazing. I had it mixed up at a paint factors and they did cost about ?9 for 500ml, but the finish is another level compared to the off the shelf rubbish sold at places like Halfrauds.
Really chuffed with the brackets. Think its important to try and save as many of the original bits as possible when restoring.
1983 1100 C
1983 1100 C
markwon said
Cheers, it is cold (car is at my parents who live on the Suffolk coast), but once I get stuck in can't stop myself. Only been painting on dry days and been warming up panels with heaters from the inside the boot.
I'm having temperature problems too - I washed a panel for spraying, and normally the small drops of water would have eventually dried off. Today, they wouldn't dry out, even with a fan heater directed at them. I guess that applying stonechip or topcoat will be no use in the current weather.
I think I know the paint you mean - Holts Dupli-Colour?
No, the place I've been getting my paint from sells Max Meyer paint systems. They'll do it 500ml cans ready to go or 500ml/1litre tin from spraying with a compressor.
I generally avoid wiping panels with water as you do know where the wet might hide, and can take a while to dry out properly. I wipe down prior to spraying with white spitirt as it evaporates very quickly in all conditrions and is also good at removing grease etc. As you say, spraying over any damp or wet is going to mess up the job.
1983 1100 C
1983 1100 C
great work on those parts there markwon, think my fuel pump brackets too far gone really to clean up.. its lower down the list of things to replace, hoping someone will reproduce them as they're quiet expensive at the moment
well done for sticking with it in this weather too.. I'm sure it wasn't this cold last year when I was doing mine
rgds volkswarren
Regards Volkswarren
rgds volkswarren
Regards Volkswarren
