Electric fuel pump for Weber carb?
So first I removed the mechanical fuel pump, swirl pot and all the associated fuel lines etc, and then blocked off the fuel return.
I fitted a Huco 133010 low pressure electric fuel pump, I also fitted an inline fuel regulator set to 2.5 psi, I replaced the disposable fuel filter with a cleanable filter and fitted new fuel lines and clips all round.
I fitted a 3mm laser cut blank where the old pump used to be, just had to shorten the bolts, electrically it’s switched from the immobiliser I fitted last year, so the ignition and fuel pump are now on the immobiliser.
Since fitted this lot I’ve done around 100 miles with no issues to report, it revs and pulls clean, yet to motorway test but I’m pretty confident it’ll be fine.
I know this is a brief post so will add some pics to better show the set up, if anyone wants more details then give me a shout.
Last edit: by nedrager
See my videos, Tom AFH
I agree the pressure regulator isn’t really necessary, and I may remove it. The reason I fitted it is I noticed that fuel was seeping past the float needle and dripping in the carb with the engine off.
I fitted the regulator to see if the problem lay with the pump pressure been higher than stated, but after a bit of messing I realised that it must have been the float needle either sticking or a bit dirty due to the lack of use, after a bit of carb cleaner all is well with no let by.
Apart from the Weber the engine is standard so well under 16bhp
thanks for the input, very helpful
