Breaking: 1990 Clipper Cabrio - 1.8 16v Converted
I'm breaking a 1990 Clipper which has been converted to a 1.8 16v.
The car has been sat for about a decade, however it does run and drive. I will be splitting the engine unless I get a healthy offer for the conversion.
Most parts available other than some trim bits. Located in Sheffield and I can post most parts.
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
Hi pal what's roof like, if good how much do you want for it?
Sent from my AC2003 using Tapatalk
The roof outer is Vinyl and split in places. it's old and brittle.
It's an electric roof, the frame itself is great and opens and closes smoothly, the rear window frame is rusted.
The internal padding seems fine and the roof liner is cream/white in good condition with one small nick in it.
The frame itself as taken of the car, £200 seems the going rate?
If you want the Electric/hydraulics, I'd have to have a look at value as I have no idea.
Hi,
What condition are the dash, knee bar, centre console, and front speaker pocket things?
Thanks.
*edit*
Forgot the driver's side triangle window, and frame.
Whip
/wip/
Noun - Car
Hello
what do you want for the 4 doortrims with pockets?
am in chesterfield so local
thanks
And also,the steering wheel
Mk1cabsportline said
Hello
thanks
Ahem.
Whip
/wip/
Noun - Car
How much for it complete
the_whip said
Hi,
Thanks.
*edit*
The dash is pretty good (other than the windscreen vents starting to  peel as they do). However, I need the glovebox tub off it for mine.
Knee bar is grey, but very good condition from what I can see. Front speaker pockets are very good, slight crack in the passenger side speaker grill, but a clean crack and hard to see, I will be attempting to fix it.
Hello
thanks
Door cards provisionally sold. As for the pockets, I have no idea. I can only find the pockets without speaker grills… So say £150?
£90?
Over £2k.
Hey Mr P
What condition is your drivers door if still available and also what would be the price
Do you have the front and rear anti roll bar clamps/brackets?
If so, how much posted to Derby?
Hi,
Do you have a working fuel level sender from the tank ?
And how much, please
Stuart
sorry to jump in have some fixings mate
g39polo said
Hi,
Stuart
gti or carb
Hi, it's a GTi
Stuart
Hi Guys,
Drivers door is actually in good condition, £30 (fully stripped)?
I don't yet know the condition of the ARB Clamps/Brackets. I've not been under the car yet.
The sender works, but I don't know if it's a GTI or Carb model sender. The car was originally a clipper converted to a 16v. I'll have to check.
Not sure if they are the same on a cabby, but I'm after the trim piece that goes over the front seat belt roller mechanism. Mines a tintop and it looks like this (circled).
Thanks.
J
Hello Mr P,
I need a few odds and sods for my cab that i've bought as a project if available.
I need:
Passenger rear seat side trim plastic panel (i'll take both side if prefered).
All the nuts bolts and fasteners for the front windscreen wiper mechs above the scuttle panel (again I'd take all the motor and linkages etc if needs be)
Steering wheel horn cover and backing plates (if the wheel hasn't gone)
Rear boot badges if they are GTI one's
Thanks and fingers crossed so I can get the car back on the road after 10 years
1988 Helios Blue GTI Cabrio project running 1900cc 8v on GSXR 600 carbs and with added porsche bits
Former Mk1's - 1983 Golf Driver 1.3 and a 1982 Golf GTI with a 1.8l 16 valve sold 1999 - CKC 66X (I would love to know if its still alive…)
Thanks.
J
One on eBay under item number 333917326590 for a tenner plus postage if that helps
Kingy76 said
Thanks.
J
Cheers fella!
Can't believe I lost mine, must be the only thing which isn't bad considering I stripped it 20 odd years ago!
J
