Car stuck in gear
(In Topic #223871)
What am I looking at here?
Gearbox still has oil, and the oil doesn't smell burned - it's nice and clean, when checked through the speedo cable hole.
I will take it apart tomorrow though - had to get away from the car, before I got tempted to find a good 2kg hammer and vent my frustration.
On the drive
Myvalver 89 GTi Grey mk2 16v
Any other suggestions?
The Dub by nature is very hard to gauge the positive effect by the stick as there is usually a lot of play in the lever system that VW uses.
Replacing all the links and bushes goes a long way in making it tighter and ensuring a positive feel, but once I used a Weighted shifting rod and short shift kit the difference in feel was amazing. I bought my Cost effective kit from 4crawler in the US, it works, and after seeing the weighted billet they added, you can make your own.
https://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
There is also the stop finger lock out that can get busticated, and I have seen similar issues as it isn't working correctly and you can never get the car in to the correct gear I will show you a link on what to check and a couple of DIY repairs of that.
http://cabby-info.com/Files/RepairingStopFinger.pdf
I will give it a go though, and try them all by hand.
What's the easiest way to disengage the clutch, so I can shift by hand? I can't pull the clutch lever on the transmission by hand, I've tried.
I have removed the driveshafts from the transmission, and managed to roll it inside and drain the oil.
The oil looks pretty metallic to me - it's only done 10-15km's.
That may account for the lever being able to move but nothing happening.
Were there any massive vibrations or horrible noises beforehand? The fly wheel hasn't come loose and dropped of jamming the clutch has it? (Don't ask how i know that this can happen) ……
Ian
It's actually not even stuck in gear. I have removed the linkage and can move the lever by hand and select any gear without issues.
I will drop the gearbox later today, and see what's going on. I'm not an expert on transmissions, but it seems a bit odd that it can be turned backwards, but not forward?
I guess the diff failed, which explaines why I was able to shift between the gears without problems.
I have started to try and disassemble the transmission (with help from BrokeVW), just to see if there's anything to see in the differential. Since the casing is cracked, I will just try and locate a decent used transmission.
Thanks for all the inputs so far.
borednow said
Boo for you!
But yay for me! I may have actually been correct in a diagnosis for once
Erm sorry
Ian
Haha no problem, I'm happy to make you happy!
Anything I need to be aware of, when finding a new transmission?
I know there's a two sizes of flanges for the driveshafts and I need the three holes to mount the studs for the rear engine mount, but besides that?
Be aware that some of the newer ones are hydraulic not cable operated. I think the cable bit can be swapped from your old one but not 100% on that as I've never done it.
Look out for ratios too.
020 GEAR RATIOS
Ian
I have an FH from 1982 fitted now. From what i can see on http://www.a2resource.com/eandt/ratios.html, the ratio for my transmission is like this:
3.46 1.94 1.29 0.91 0.71 3.89
Now, where I live its more or less only transmissions from diesel cars that are still availible. I have found a few 4T, where the ratio should be like this:
3.46 1.94 1.29 0.91 0.75 3.67
Flange and input shaft sizes are the same, so I guess it would be a good alternative?
I would recommend fitted some new seals to a second hand gearbox as it's alot easier with the gearbox off the car, follow the guide on the brokeVW site to change the flange seals and may be worth changing the input seals and brass bush.
A set like this
https://www.ebay.co.uk/itm/VW-Volkswagen-Golf-Jetta-Passat-Corrado-Vento-020-Gearbox-16v-8v-Oil-Seal-Set/112445735476?fits=Car+Make%3AVW&hash=item1a2e49c234:g:BvAAAOSwxeVefpqT
I would also remove the green cap and check/replace the clutch release bearing but this is possible once the gearbox is on the car if you don't want to do that job as well….
You can see some info/pictures and my home made tool to remove the flanges in my post here… a bit of threaded bar, nuts and some sort of box section and it's made.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Funtitled_14
Changing a Differential Seal | Volkswagen Owners Club Forum
I replaced the seals on the current one, not too long ago. I did it with the transmission installed, so I will do it before I fit the "new" one.
I have bought a complete seal kit - but without the brass bushing… where's that fitted?
I can see that my old box was higher geared in 5th gear, so I don't think the 4T transmission will cause problems ratio wise.
