Rocker cover gasket?
Rocker cover
VAG torque spec is 10 Nm if you dont have in/lb markings on your torque wrench though you'll need a little one to get accurate results as the larger ones dont tend to work so well at low figures.
VW specify sealant D 454 300 A2 on the corners of the bearing caps, but you can use your preferred assembly sealant
