My 1983 Golf CL AFH conversion
borednow said
Should have gone twin carbs with mine…
What rear mount have you gone with?
Ian
I used the factory 1.1 liter rear mount. I had to notch it to fit but it works. Trans mount is custom made by a guy in The Netherlands. Webers are great but have been a pain to tune since I had to set my own timing curve too. Timing effects these carbs in a huge way, 2 degrees and it falls on it's face…
Last edit: by nedrager
See my videos, Tom AFH
Anyway, pulled some timing out of the top end today while I was doing a bit of testing and it woke up the dragon… I was extremely concerned because I still have the brakes meant for a 1 liter 50hp motor…
With luck I will post a video from the street and maybe one from the dyno very soon, stay tuned.
Also sounds like time for a brake upgrade
Matt
Test run with new timing map 1,4L AFH 16V dual 40 Weber 151 - YouTube
If you line up all the TDC marks on the front of the motor you would typically line up the distributor rotor with the hash mark on the edge of the distributor body (sorry no pics, pull the cap off and you'll see what I mean). This works fine on the original computer controlled setup… In my setup with all marks aligned I had 60 degrees of total timing advance. My ignition system is able to retard 25 of that total at idle and slope it back in however I see fit. Problem is that 35 degrees of advance at idle, which explains why my starter and flywheel failed earlier this year.
So now I spun the distributor full retarded. After counting the teeth on the crank timing belt pulley (24, I have all the plastic belt covers removed) I determined one tooth is 15 degrees (24*15=360). So now, full retarded, I have 15 degrees of advance at idle using the beveled tooth on the pulley and cast mark on the front main seal cover as a reference. I slope in another 18 degrees for 33 degrees advance total at 3400 rpm. I could bring in more timing sooner but the engine is already hurt and trying to keep it alive for another week or two.
I'm still working (stalled) on building a 1.6 stroker AFH… But the 3rd AFH motor showed up today and will get swapped in late next month. I did acquire a knock sensor computer (KS4 from Phormula in the UK) to wire up and slave into my ignition system MAP input. I'll be using the 0-5V output of the KS4 to drive the 0-5V ignition input which is normally used to read boost pressure and pull timing based off a map I create. The car is ridiculously fast now even with the engine damaged, I plan to upgrade the brake system while the motor is out this time.
So the saga continues…
borednow said
Yup, read it, didn't understand a word!
Brilliant, there myself quite often.
Here's a vid
https://youtu.be/QBHRJfhuz_s
I'll post that stuff in the proper forum later this summer.
https://www.dropbox.com/s/ujj85gsb5pq49ia/test1_Medium.mp4?dl=0
nedrager said
Short vid attached… Pull toward the end is second gear 50kmh to over 190kmh. Everything runs pretty well. I'll be off to the dyno when I get back from travelling for work. And then this motor and trans will be pulled and sold to make room for the refurb'd stuff. I'll be parting with several gearboxes as well, some better than others…
Love the sound of the little lump
Is the engine/cam etc standard?
I guess you would quickly get in the 120-130 horsepower area with a good streetcam
What is the redline currently?
1982 - Mk1 Golf 2.0 AGG 8v - 158 HP / 202 NM
_________________________________________
Hurtig said
Love the sound of the little lump![]()
I guess you would quickly get in the 120-130 horsepower area with a good streetcam![]()
Motor and cams are standard bits. I'm off to the dyno soon enough but I think I may have 120+ at the wheel already. Redline at the moment is set to 7500.
https://www.youtube.com/watch?v=dlc5wVWdTw0&list=WL
Don't know what kind of dyno it is, but it made 142BHp. Peak torque at 5300rpm, peak HP at 7300. I was really blown away since I got this motor and trans for 300 euro and haven't don't anything internally to it. Power seemed to level out after 6500, could be the head flow maxing out or my chokes. I'm going to try my 36mm chokes soon, currently running 34s. That'll be the last thing I try before I start the 1620cc build.
Mine made a touch more but the entire engine had been rebuilt.
Mine also levelled out at 6500 revs so it must be top horses at that point, probably due to head restrictions as you say.
It's enough though!
Enjoy
Ian
I've also ordered a set of 45s, 152G 5 hole versions meant for a Ford 2 liter ZETEC 16V. The 3 hole 40s, mine modded to 4 hole, still give lean stumbles in the transition phase. The 5 hole Webers were brought about to correct this very issue. Plus, the 40s are maxed out on this engine. Flow numbers suggest it flows like it's a 2 liter. I'm running 34 mm chokes, tried the 36mm but the vacuum signal is a bit weak. The step down from 40 to 36 in the carb doesn't put a very strong vacuum signal on the jets and makes it react sluggishly. I'll be running 36 mm in the 45s, but the step down from 45 to 36 gives a better vacuum signal, thanks Mr. Bernoulli. I'll get maybe 20% more air through the 45s with 36mm chokes over what the 40s will do with the same 36s, additionally the vacuum signal will be much stronger on the jets to help them react a bit crisper. Hopefully I can swap the jets over and be near where I want to be with the mixtures then it's back to the dyno for one last run before I swap in the fresh motor.
Took the Gold RH wheels off, they're available if someone wants them. Also this motor and carbs will be available soon with the matching gearbox.
Yellow is torque in NM
Blue is horsepower in kW
Red is crank horsepower, using the correction factor in Green.
