Mynx the Tintop 1400 16v afh bike carb'd restomod
Back up and running and for sale!
Primer around the tailgate area, isdie of door panels etc
Engine bay sanded, and checked and a bit more work done
Rusty bit on the arch cut out and replaced and bumper mounting hole removed.
and a naked full frontal just for
The doors, tailgate and bonnet have all been primered and a bit of paint has been thrown about.
Did have a bit of an issue when my spray booth racking decided to collaspe
At the time it had the tailgate on it and i was just installing a door on it too. Flaming thing decided to collaspe, just missing my head but did drop the door and the tailgate on the floor! Luckily I seem to have gotten away with just marking some of the paint on the tailgate!
Painted tailgate
Door painted
Just got to chuck some paint about, sand everything back, clear coat, sand and polish!
Oh joy!
Hairyarse said
Nice one!!![]()
Ta
SamGti said
keep up the good work and great posts too! ive been at the stage of needing to find somewhere i can get the car inside and weld it myself so this is helping with the motivation to pull my finger out!!
Wow I don't think I've ever motivated anyone before! Crack on then, get that finger out and get her done!!!
Keith Usher said
Good work, but you either need to turn the welder power up , or the wire speed down for a better penetrating/wetted out weld.
Cheers for the tip mate. I think I had the wire speed up a bit high, if I turn it up anymore it's tends to blow through all the time. The wire feed is a little temperamental, there's a modification I needed to do it to make it better, never quite got around to it though
Thanks for the replies chaps, I was begining to think I was talking to myself, which admittidly, isn't that unusual. Luckily most of the voices in my head have been quiet recently.
Anyway, in other news:
Prep for the paint to the outside is nearly complete!
Piccies coming soon
Ian
If your wire feed is jerky you are screwed from the start.
Keith Usher said
if you find you are blowing thorough try to learn a pulse welding method, you weld a zap then off then zap then off, this allows the weld to cool and solidify between pulses and not burn through, have a go on some scrap metal.
That explains it then. It turns out I'm not useless after all! Yay
So todays works have seen the body mostly ready for paint.
Paint should be going on next weekend with any luck!
Ian
Mynx the black golf 1400 16v afh bike carb'd restomod (name change!)
Hello mate, I've just ordered track rod and end from eBay , here's the number to search 190518605313 they fit both sides and will give you adjustment where before there was none and as for the wing can't you buy repair arches and nick a bit out of one of those would probably be the easiest way.either that or cut out the section you need replacing send it to me with a stamped addressed envelope and I'll make it for you at workborednow said
So then another 9 days have gone rapidly by.
Managed to get a bit more done.
Finally got the fuel lines to the pump sorted, installed the fuel pump in it's final resting place and sorted out the length pf the cabling for it.
Removed the rear screen after srapping on the big boys panties and going for it with the patented 'Brother in law in the car and pushing with his feet whilst I catch' system (a bit nerve racking to say the least!)
Finally I managed to get the back end on the ground, after finally finishing everything at that end (hopefully!)
So took out the engine again, jacked up the front, axle stands installed, steering rack out and all suspension etc off! Yay
The rack needs two new ends so just got to decide the best way to go about it. New rack and two new ends or just the two ends. One of them is the fixed, non adjustable end so that may cause some issues!
suggestions welcomed!![]()
Found out the leading edge pf the drivers side wing will need a bit of work. and there was I thinking the welding was done![]()
Also done a bit more tidying to the bay and managed to get it all into Etch primer, so at least that's moving along a bit now
So that's about it really. Many days of hand sanding an engine bay will tend to east your time away!
Just got to come up with some clever way of fixing that wing now!
Later
Ian
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
Missed a bit of a trick there, I could have had a good bit of fabrication on the car!
Thanks for the offer though!
Last edit: by borednow
Luck was with me (kinda) for the week and Sunday saw the paint go on.
Yup, it's staying bare metal. It's been cleared with the best 2k clear coat I could find. 5 coats in all, with 6 on the front panel and leading edge of the bonnet.
Yes I know it'll get chips, yes I know it'll probably rust from the inside out as there's no sealant layer, yes I know it'll probably peel in places as it wears.
But although this is my 'daily' I have a works truck and this will be garaged (when it's built later this year) and will 'only' be used for the 3k miles I do outside of work. Plus keeping it well waxed and keeping on top of any areas that need attention will keep me busy and stop me buying another one! Well except I've still got to do Ujum yet
My biggest concern is the glare and reflections from it in the sun.
Hopefully now some of the weird stuff I've been doing, lead loading, painting the inside etc might make a bit more sense!
We shall see, if I have to paint it, I have to paint it. At least all the hard prep works been done
+ did you check the track rod number I sent you for eBay, I can imagine you've been quite busy I'll let you know how I go with fitting mine when it arrives
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
mike.d1979 said
That looks awesome.![]()
thanks mate.
jamie8v said
Wehey ! That is brilliant! Where do you keep the flux capacitor? Dude you are more than welcome for the wing thing but I think you did the right thing,you can't beat a bit of original panel, even if you did find it growing in the garden lol, do you think if I planted some wheels and picked them early they'd come out the right size ;-)
+ did you check the track rod number I sent you for eBay, I can imagine you've been quite busy I'll let you know how I go with fitting mine when it arrives![]()
Flux Capacitor? Under the dash with the time circuits of course!
If you planted wheels in my garden, you'd have a crop of whatever you planted plus, BBS RA's, OZ Volcanos, OZ tourismo, 14 inch steels, 3 sets of 13 inch steels, a couple of toyota wheels, a bonnet, a door, 2 clipper kits and god knows what else! Could be an interesting variety of wheel!
I did check it out, ta for the link. I've already ordered some Meyle ones. After a few years of messing about with Golfs I've discovered that sometimes some manufacturers a a little better than others. I currently trusting Meyle. But we shall see!
For Gods sake avoid JP group parts! They fal apart by the time you've fitted them!
By the way if you have the original boots on your golf look after them! I've had to replace them every year on Clive as they always break. I'll have to do them again this year. Luckily Minx's were all good and a little cleaning has seen them looking brand new
lemon yellow 83 mk1
e39 bmw 520i msport
missus' peugeot 308
have had everything from AE86's to E30's to vtec hondas….this is my first VW.
i'll definitely need help
e39 bmw 520i msport
missus' peugeot 308
