Lights left on warning buzzer with genuine parts
Any help gratefully received.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
mark1gls said
Try leaving for fan blower on 1,2 or 3.
Nope that didn't help
Can I put 12v on it and test it like that, I got if from Stevens VW Dismantle and it has a signature on it (as does the fog light switch I purchased at the same time) so guessing they've tested it.
When should the relay buzz? Is it key out of ignition or just turn the engine off?
Last edit: by Pete M
Pete M said
Got my 292 today, fitted it but nothing.
Of no help but I get the same results!
Sent from my Smartphone
Perhaps it's something to do with the change of fuse box which your car has???
So it works with the wiper lever up or down but not in off…
Adam
The headlight switch has a little bulb that's on constantly when the car is on or running so you can see your switch in the dark when you need to put your lights on.
Try this, if not check fuses and for wiring faults. If all else fails try a replacement fuse box
I know i suprise myself sometimes with my geniusness ness
adz25 said
I had the same it didnt work, so just left it in. Today i was removing the binnacle and clocks, accidently pushed my wiper up with the ignition off and the warning buzzer came on! So it does work, but will only warn you if you left your lights on if it has been raining! Any thoughts??
Adam
Same here!! Any help?
Two minutes later, I revelled in my success.
Thanks!
92 Fashion Line cabby (New Girlfriend )
89 Black Clipper Auto (Lost)
83 Black GTI Engineering Resto - (Minty!)
05 PD Passat daily driver (unbreakable)
I got me a 1987 GTI Cabriolet - Quartet in White/Blue/Blue
