Carpet underlay
Have you had a look at Woolies website. They seem to do a lot of trim parts for classics. They had a stand at the NEC last year and had a roll of sound deadening felt about half an inch thick but without the bitumen layer. They also do sticky bitumen pads for inside the doors-but are expensive
Yeah, I just tried to remove rust from it with a wire brush. Turns out it's more like bitumen, and the "rust" was just dust from the underlayrubjonny said
yeah you will have a layer of soundproofing stuck to the floorpan, im not sure exactly what it is made of. its easy to mistake it as the floorpan of the car on first glance but if you look closely you'll see it there
Are you saying I don't have to remove it to put sound deadening down???rubjonny said
any track car build thread you'll see the poor bugers trying to remove it![]()
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Hard way scrubbing rubbing and wire-wheeling it to submission.
Heat gun and a scraper work.
Easy way, Dry ice, place dry ice on it for a few minutes, then smack with a rubber mallet and it breaks apart, move the dry ice to new location and repeat…..
There are plenty of threads on the vwvortex where this was used successfully.
Shocky Jr. Updates
What is the benefit of removing it?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Carpet underlay
It’s the felt stuff so it’s pretty decent thickness.
The carpet always pulls away at the door sill.
So if you put more in and text fit the carpet you’ll judge how much is needed.
As the old stuff wears the carpet sinks pulling away.
I put a layer over the centre tunnel, up the back behind the pedals and Into the foot wells.
Interesting what you say about the carpet pulling away. I was planning on using CCF there, but perhaps that's a bad idea as it will compress a lot underfoot. Maybe just underlay there then. I was thinking of the Newton pre-cut:
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I will say this my 81 Diesel over the 20 years of ownership never had this issue, and I had over 330Kmiles on it when I sold it.
but then again I had the LS model which had the better carpet and padding.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I've alwyas felt that it should be non-absorbant, even though the the original stuff isn't.
Sadly the links that RJ posted orignally no longer resolve on ebay (hardly surprising, it's been a few years!). Anyway, I found this on Ebay which looks good:
https://www.ebay.co.uk/itm/3m-Adhesive-Vehicle-Car-Underlay-Sound-Insulation-Heat-Car-Van-Camper-Boat-11mm/263936584776
Certainly non-absorbant.
J
The second one is twice as dense as the first, and slightly thinner. It probably compresses less which would be good reducing carpet slippage. Perhaps I'll skip the Newton stuff. Quite expensive though. Similar to covering the same area with thinner CCF and MLV.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
What I've ordered doesn't represent my final plan as I'm learning a lot all the time.
So far I have:
CLD - (Bought before I knew you don't have to cover completely)
https://smile.amazon.co.uk/dp/B00020CB2S/ref=pe_3187911_189395841_TE_3p_dp_1
https://www.ebay.co.uk/itm/401862304569
On the way:
CCF - (Light so I don't mind using a lot. Got 8mm and 4mm stuff for various areas)
https://www.amazon.co.uk/dp/B07QW2RL2Q/ref=pe_3187911_185740111_TE_item
https://smile.amazon.co.uk/dp/B07TKXCN6F/ref=pe_3187911_185740111_TE_item
MLV - (This might be too light as it is only 1.5mm)
https://www.ebay.co.uk/itm/263934654841
Whip
/wip/
Noun - Car
/wip/
Noun - Car
These are attractive. What are they?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
There is one ugly one in each footwell. There's no rust, just stains that look like rust. I'll check underneath. Cheers.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
