Monkey's 1974 BMW 3.0CS
Campaign Mk 1 Black
16v Mk2 Red (decsd )
Marketing Manager
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Marketing Manager
I was a bit worried that being jacked up on one corner for so long would have distorted the chassis but the shut lines on the car are perfect. The clutch pedal was not moving, initial thoughts were master cylinder was seized as there was absolutely zero movement. Removed it and after applying a small amount of pressure to the rod end that connects to the pedal it squirted fluid across the garage! Reinstalled it but it was not building any pressure whatsoever in the system. Thought a line may have been blocked so attempted to purge the system with a compressor from the slave cylinder, however the master cylinder had been incorrectly repaired at some point and the small washer was incorrectly installed allowing for the metal pin to pop out of its socket, reapplying the pedal promptly broke both pin and master cylinder. Luckily both were repairable which is just as well as a new MS for one of these is daft money.
Also, had a chance to look underneath the car, the floorpan seems solid (with the except of the O/S which I knew was rotten), Both inner sills are gone at the front, but for peace of mine all 6 sills will be replaced.
The original metallic turd brown is also slowly growing on me….
Marketing Manager
What a face that isNosmonkey said
Couldn't resist putting her face back on the other day, I really need to get cracking on it.
Chairman
Marketing Manager
Marketing Manager
Marketing Manager
BUT the front brakes are freed off, clutch is being a royal pain so need make up a braided line from the MC to the SC apparently. So clutch and clean up some more stuff around it and jobs a good 'un.
Oh yeah, and I cleaned it up a bit, turns out you CAN polish a turd, especially if it's metallic and has questionable rustproofing measures.
Marketing Manager
Great to see it on the move. 😉 👍🏼
Sent from my Smartphone ☃️
