My car audio install
Secondly I wanted to show how the door pods fit in relation to the dash. In order to keep that stock look, the lower door pods needed to be made to be as close a fit to the dash as possible. So the angle and size of the bevel had to be exact taking into account the addition of leather not only to the door card, but also to the pod itself front and back. To help anchor the rear of the door card at the door pod, I used the standard door poppers but also Pond liner repair tape which is like a black, super sticky butyl rubbery putty stuff. The same stuff as was used originally at this point on the door card by VW. But for those of you looking for this gunky black stuff, its pond liner repair tape. (Not really tape as the name suggests, its like a super sticky strong putty) Without the black pond liner tape putty stuff, the door cards may pop off at this point due to the weight of the speaker and pod. It also reduces vibrations at that point.
Design Manager
I don't want you to see my previous post as overly critical nor was I trying to put you down for the selection of components and your install. You clearly know your stuff and have chosen some really highly regarded components not to mention your attention to detail. You are the first person I have seen on this site to go above and beyond when putting audio gear into a Mk1. As I said, you clearly know your stuff and I feel that I have a reasonable knowledge of car audio purely from having worked in the industry for a few years, however I don't see myself as an expert, far from it.
No one can explain how something sounds, there are lots of people who will not appreciate the quality of sound and as I was trying to explain before you can get a really good quality of sound from speakers that don't cost the earth that are in a decent enclosure. As a direct comparison, I have heard a mutant twin 10" £16 bandpass enclosure far outplay a 12" JL Audio 10" W7 driver in a tuned ported box playing from the same JL Audio amplifier. The quality of the sound from the mutant was far better because the enclosure was acoustically better designed and as a result the overall musicality was better.
To me, the fact that the stock Mk1 door cards are made from hardboard and that the speakers aren't fixed to the metal door structure in any way means the speaker enclosure is not optimum. The door card will flex and the speaker will not play to its full potential. For this reason I remade my door cards from 8mm ply with 15mm MDF speaker rings all screwed to the metal structure of the door card itself to prevent this. You mention the black sticky putty stuff above (I know this as Dum Dum) which you have used to stabilised your main drivers, this is exactly what I mean, you have had to use a less than ideal solution to keep the speaker sealed (Albeit probably the best solution for the Mk1 stock location). I chose to use 5.25" speakers because I could fit them into the door cards in a slightly different location to stock which I found to be more stable. In simple terms what I was getting at was that if you want the best possible sound (Which clearly you do) then the Mk1 is a very poor base on which to start. If quality of sound is your main goal then there are other VW's which have acoustically better designed doors and chassis' (The Mk4 comes to mind) which will take full advantage of the component quality you have.
All of that being said, clearly I am also in love with my Mk1 as much as you and as such I can fully understand why you would want to spend the money on it. I'm just personally not sure I would spend so much time, effort and money on an audio install to try to get a better and better quality of sound from it when the car has its limitations and as such I can't see the money being worth it. Please don't take offence from that, I'm just voicing my opinion. It's your car and your money and obviously you can do whatever you wish!
I'm sure if I bump into you at any point that after listening to your car it will sound excellent, but it could sound even better. That's all I was trying to say.
Do you own any other cars with installs? I would be really interested to see photos if you do!
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Design Manager
Having worked in the business yourself, I am sure you are aware of some of the equipment used in setting up an active set up in a car. RTA (real time alignment) equipment etc.. For most people, this would do the trick for setting the sound levels and even as a tool to set the time alignment in the right hands. But I am fortunate to have a friend with the most accurate sound measuring equipment available, who is going to help me set up the system. He helped me last year with the previous processor and my God.. It was phenomenal. So hopefully if we can achieve even better results with this new ODR P-90x processor, then I think the car will be at SQ competition standard.
It will never win any awards for bass, you are quite right and mentioned that in your first post, however, there is still plenty there.. I think the strengths of my system are that the angle of the drivers and cabriolet roof mean the reflections are nil. Combine that with perfectly set time alignment (emphasis on the perfectly) and the quality of components and purity of signal and it really is into competition level stuff..
Hopefully I can get to meet you at one of the shows this year. My aim was to set the bar high, and by that, I mean fit the best car audio in a Mk1 golf cab ever.. Whether or not I have managed that is open to debate, but I am quietly confident that you will be impressed regardless of whether I could have got close to that quality for less money. Because that was never really a factor in the build.
I think when people build a show car, either restoring or as in my case, upgrading, they must have that desire of perfection and nothing less. There are a lot of good cars in the car show world. To win anything, it has to be in a different league. I do compete to try and win. But rather than wanting to beat other people, I want to win for myself. As a personal challenge, you know.. I look at other cars as a bench mark as to how good my car has to be and these are factors that influence my install and interior. I may win some, I may lose some. But I want my car to be the one that everyone would love to own.
Design Manager
If you are talking about entering the car into an SQ competition then really my previous argument is null and void because you do want the very best you can afford fitted to the car to make the sound as close to perfect as possible. Especially if you are also utilising RTA.
I am also totally on the same level as you when you speak of putting your own car in a different league etc. It's something I think as a car enthusiast we all strive for. Keep up the good work walt and as I said I hope I bump into you at some point soon!
I personally loved the aesthetic of the 6" driver and pod and tried to improve the cabinet as best I could, given that it is a car door at the end of the day and have finally resigned myself to the fact that in order to play lower in the doors, I am going to need bigger bass drivers in the doors. There is no getting round it. It has to be done.
I am sure that some of you reading this will be wondering, "surely the sub woofer will compensate for the lack of bass from the front bass drivers?".. Well yes it does. However, the higher the frequency you cross over a sub, the more directional it is. So at the 80hz crossover point I have it at now, it is noticeable that the sub is in the boot. The lower I can get that crossover frequency, the less noticeable its location. Ideally I need to get the doors playing down to 50hz.
So… I have purchased a pair of the best 8" car audio speakers that money can buy. For the car audio geeks out there, they are the Seas Lotus 8" drivers. To house these beasts, I have had to make new speaker pods. They took me a few days to make because of the complex design. But they are finished and with the trimmers now having the same black vinyl finish of the earlier pods. It is costing me £200 to trim the pods up and this was priced as a favour because I have had so much work done by them in the past. Here are a few pics of the new pods I made. I will put more up when I get them back from Autotrim in Denton.
1.8T CABBY
1.8T CABBY
1982 3 Door - 'BRO' - gone to pastures new
1990 Clipper Cabriolet - Jet green metallic
walt said
Quick update for anyone interested. Following all the upgrades shown previously, I (with the help of my friend and his sound monitoring equipment) set about setting up all the fully active adjustments.. Volume of each individual speaker, the cut off frequencies and slopes with the crossovers and most importantly, the timing. The soundstage and depth of field are playing well outside the car. What I mean by that is that if you close your eyes, you have no idea that you are in the confines of a car and would believe yourself to be in a much bigger room.. This in itself really impressed me but with just one issue niggling me. The 6" speakers in the doors just cant play at a low enough frequency. This is down to in effect that the speaker cabinet comprising of the pod, door card and door itself, being unable to allow the driver to play any lower rather than the driver itself not being capable.
Hi Walt amazing workmanship there! Would be a shame to cover them up. Varnish sounds good
I understand that it wouldn't be in keeping with the rest of the install and the existing trim looks amazing anyway.
The seas mids look great, you are going to enjoy some sweet mid bass
Really cheeky request but would you sell the 6" pods?
