Fuel Pump Relay 'Problem' - Mk1 Golf GTi 1.8
Last edit: by Pete Zwanepoel
My '75 1500 auto has twin carbs on, it's had a facet electric pump on for about 20 years, last year i got a filter/ regulator fitted also.
A number of years ago i fitted a fuel pump override switch for an extra level of security though this was incorrectly wired due to my limited electrical knowledge at the time.
A relay for the pump should have been used, though can i still have the kill switch for when it's parked up and whatnot and still use a relay that works from the rev counter signal so that it kills the pump when the engine cuts out?
obviously, it's an early ceramic fusebox that i have. but i can follow a diagram if a remote relay is to be used.
cheers for any assistance. oh and happy new year!
87 - power out, fused for pump
86 or 15 - ignition live, G spade 3 will work or you could tap to coil power, or whatever
31 or 85 - earth to claw near fusebox
1, 31b or 85b - rev counter signal, tap to coil negative red/black
rubjonny said
yep you can wire the kill switch inline with the ignition live or the rev counter signal to the relay, that way there is no load on it
Nice one cheers for that and the lower reply, much appreciated
