Fuel Pump Relay 'Problem' - Mk1 Golf GTi 1.8
(In Topic #186537)
My Golf won't start
That's the easy bit Basically it's the fuel pump not pumping. The pump works and the engine runs like a train when the relay terminals are bridged. Obviously doing this leaves the pump running with the ignition off, so not a good work-around.
The relay has been replaced - no joy there. The relay I has sold doesn't have a fuse on top as described in Haynes (but has all five terminals).
I suspect there is a problem with a signal getting to the relay, but don't know enough about vehicle electrics to even begin to know where to start.
When the engine is running the rev counter works (don't know if this is significant, but it may point to a signal from somewhere being Ok).
Help will be greatly appreciated - thanks
Golf GTi Mk1 1800 (daily driver)
Alpine Renault A110 1300S - driven when working!
Suzuki GSXR750W - for the days when the other two aren't mad enough
the relay is triggered by the rev counter signal from the coil, the fact your rev counter works suggests this is fine but if someone has bypassed the fusebox this could be the issue.
if the wiring to fusebox is ok then it would seem the signal isnt getting to the relay socket, perhaps it has suffered water damage? the revo pin on the relay is 31b, so look at the corresponding socket on FB for obvious damage
Yes it is the later blade type FB.
if the 18 relay doesnt work then this points to either the ignition live or earth terminal in the fuel relay socket at fault, rather than the rev counter signal
TBH - searching the forum I found the 17/18 relay in other posts.
Thanks again
Next job fit the 16V master-cylinder & servo
Max13082011 said
Hi, I've a mk 1 1.8 8v cab, I've a fuel pump issue, car only running few days ago, now pump won't even prime off of key, I've changed the relay and I can hear it click but no change, any ideas what prob could be or how I can check pump before I buy a new one? Many thanks
if the cab is post-84 it has 2 fuel pumps 1 in the tank and one under the car, if the tank one fails the main pump will eventually die as well
Resurrecting an old post but just found this when trying to sort why my car wouldn't start today and I couldn't hear the fuel pump,prime when switching ignition on. Using the no 17 fuse it fired up straight away, so just ordered a new fuel pump relay. Thanks for your tip rubjonnyrubjonny said
they dont always prime, but to check the fuel pump and wiring swap the 17/18 relay into the fuel pump socket and the fuel pump should always be on with the ignition. if so look at the relay and the rev counter wire as above, if not look at the fuel pump and wiring from it.
Ive got a similar problem with my 1984 gti 8v mk2.
Its hard to start when its cold. I have to use a "startgas" to help it start. Ive unplugged the coldstart valve contact and used a multimeter but it seem dead. It only went to 0.89v when it should go to 9v?
My questions are. Where does the wires goes? Is it a ground issue? Are there any relay to this? Ive read there is a relay 43/53??
I took relay 43 out once beacuse my watertemp went crazy. Does this have anything to do with this?
