Non-chavy looking radio?
jellybelly said
Nice write up.
Mrs Choc Rolls Stock!
jellybelly said
your a genius thanks!!
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
I looked for ages, into retro, old stock, and converted units… I settled on a blaupunkt, as it came with a blaupunkt brand unit from factory.
It's called a 'blaupunk madrid', has a nice square styling that suits the rectangular mk1 dash.
Looks better in the car than any of these pics though tbh.
That one on ebay you got looks sweet, get some pics up of it installed!
As for wobbly / non snug fitment… there seems to be a lack of support for head units in a mk1 dash. If you find a solution, share it!
Last edit: by Mogs
mazza411 said
Anyone know how i can make the radio fit more snugly? i will fashion something to support it at the back but is there any for of surround i can use to make it sit with the dash face better? cheers
I was struggling for a long time to get mine to fit nice and tight
I'm having the dash out I a week or two ill take some pictures of how I did it
You need to remove the tuning/volume dial knobs, remove the plastic fascia and then there should be a metal plate that is just bigger than the DIN slot with holes for the dial stalks and screen. This and the main unit go into the dash then position it against the back of the Radio aperature and refit the fascia and dials to the outside.
The pic below is of an original early Mk2 Blaupunkt, you can see the plate behind the plastic face:
If you could that would be very much appreciated! cheers
GavB95 said
Early blaupunkts are smaller than the DIN size and don't use a cage, instead they have a sandwich plate that sits behind the plastic fascia.
(if i has worked) I dont have this plate, would it be something i can fit?
Last edit: by mazza411
I would make up a sandwich plate, just make sure the material you use is sturdy enough.
