Mk2 Golf 20v turbo, car is now near complete
(In Topic #153664)
Built to go not for show
This one kind of defeats the purpose as its built but technically its not 100% finished…
I bought this car for £350. I wanted any colour apart from red and an original big bumper model. This was neither, but the body was rock solid and at that money I couldn't a say no…
This was the car receiving its first clean and polish and I put a set of bbs ra on it and a single lamp grill to see what it was like.
My buddy Andy helping out👍
Cross hair lights I had as the clears were done
The paint came up amazing using G3 products I was well chuffed and the tornado started to grow on me.
This was the bay
So after I got the car cleaned up the strip down began
Subframe off
All other parts off
Doner car bought for £190
Then the cleaning and painting began
Clutch master cylinder and passat pedal box in
Inner arches cleans and painted up
Wishbones on
Started cleaning up the cross member
Cross member in with new front brake lines
Corrado steering rack and boot plus the mk4 golf shifter tower
Hubs with there new bearings waiting to go in
Anti roll bar links being cleaned for new bushes
G60 brakes nearly brand new black diamond disks ready for clean up
Strut tower being drilled for compbrake solid top mounts
Removing uneven seam sealer using heat and a chisel
Removed
Have a bit seam sealer to repair on this side but il get that.
Brakes painted and on with the new ball joints and track rods
Goodridge hoses on
G60 arch on
And dash stripped for wiring and pedal box assembly
New side skirts clips and and sticker strip
Il post some more up when I manage to find them
Hairyarse said
Nice work so far. Those Recaros look comfy!![]()
The back seats are even better.. It's a corrado rear bench and there super snug.. Plus there's no rubbing with 3 in the back
smudger1980 said
Very nice work indeed mate. What's the engine spec? Standard?
Cheers mate.. Engine is a stock 225 BAM only mods in there are 4.5bar fpr, forge tip, k&n cyclone, 2.0L tfsi coilpacks, fmic, straight throu 2.5" stainless exhaust, qpeng downpipe, emerald ecu with 3 interchangeable maps plus flat shift, stage 2 clutch, tech edge wideband lambda and soon to fit a Collins actuator and Collins bov.
Is a 4.5bar fpr needed? I thought 4bar was more than enough for modding that engine?
smudger1980 said
Nice spec. Not quite standard then
Think its a 4.5 I would need to look again but when they get mapped it all gets sorted out then
golf_coupe said
Cheers daz
My mate come down with the old faithful
Standard g60 fly there which was brand new vag as the lightened one i paid a fortune for from America was causing problems.
In it goes
Home sweet home
Lost a lot of pics but fwd now and got a seat Toledo tdi twin fan radiator in there, lucky find in the scrappies… It's huge and fits factory mounts
Fmic on and in place..
I cut out the lower part of the front panel bolted this in place the my mate welded a tubed braket to the front cross member then that got bolted to the underside of the fmic.. Painted up bottles in. Fits snug
golf_coupe said
didnt know flower was givin you a hand with this![]()
Thought I would put his nosing to good use
This is how its sitting for now
Feeling sorry for itself in need of a good clean
Cant wait for the day when back to black is all that's on my mind
