Engine Block Paint
Mars red Tin top 83' gti in progress
RobinFromFrance said
Hairyarse said
Shughy said
Did mk1 golfs come with a green or black engine block?
Black
Hi,
I've got green blocks on my diesels…
Robin
Really? Blimey, missed that one. I was thinking GTI but did think all were black anyway.
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Shughy said
Yea I think some of the Irish mk1's had green block too (dentdoc had a theory on it) I thought they were all black, I'm going to paint the block satin black with an aluminum finish on the head and aux bits.
Doing something similar as we speak.
Block in black, oil cooler, WUR etc in silver but leaving the head in original, just wire brush / wool it and clean it down.
2nd coat is on , 3rd coat tonight and the Aux bits are already completed.
Like this now using hammerite spray and Halfords vht aluminium finish.
Only thing is the vht has to cure when the engine is running which ain't much good for builds as it just come off in ur hand when dry, so iv used a heat gun which has cured the problem!! Cured get it? Lol
Cured gag - tumble weed!
So far I am delighted with the finish.
Massbad69 said
Dubbuds your engine looks great mate !!
Thanks man so does yours! Nice finish, Looks mint
Sorry to drag this thread up but I was wondering how I can cure use VHT paint if the engine is out the car? Is it possible if not being fitted for months or should I use something else? After a Matt black for block, rocker cover and exhaust manifold.
I think I can BBQ the manifold but not sure about block.
Not sure if I get you though..
bmouthboyo said
Hi guys,
You can use an industrial heat gun (hair dryer). This will warm up the pain and the block to get the paint to cure.
I have also used Quartz/Halogen lighting to warm things up, the Radiant heat from the lamps can get things toasty. They are the Same lamps that I used to heat my Garage up to 88 degrees when I work on Vert tops in the winter.
My Brother and I used to use the Charcoal grill to heat up Manifolds and such, but the issue is that you have to keep the paint about a foot off of it so it doesn't get a direct heat….If the heat is too close then you can get burned or blister the paint so you have to start over.
We would usually wait for Mother to leave for work or somewhere, then we would use the oven.
It was easier to control the heat.
My Brother bought a large Electric Oven from a Restaurant that was going out of business, and he uses it for Painting, and Powder Coating. He can put 2 wheels in it at once….
Engine Block Paint
