Jellybellys LD Diesel Front end resto begins!!
Jellybelly has joining the Turbo Diesel Club!!!
DubPartz
DubPartz
jellybelly said
if you need a hand with the wood i can machine you some new stuff
just need to wait for my grandad to finish my feet then it will be going on![]()
Great stuff, will give you a shout. Thanks
DubPartz
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
New ICE install
and this weekend i have been getting it ready for the daily roads
hopefully i've been told correct
Before:
After:
also bought from the states a Girling caliper rebuild kit
enjoy!
Twitter Manager
Just a thought on your brake issue - you have the diaphragm vac pump which is notoriously bad. Perhaps you have very little servo assist?
I am not going to be too far behind provided the Guru has is blessing on Feeby :mrgreen:
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
well stanford hall didn't go so well as i broke down on the M1
not good times
got it home and did a compression test and something wasn't right
so the engine came apart
cyclinder head off and on the bench
normal cracks inbetween the valves
and this crack around the injector housing
so after it sitting in peices for a few month while prparing for the AGM, now it's over the rebuild will begin
The engine had a lot of life in it still
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Twitter Manager
also big thanks to GSF Leicester for helping me source all the parts i needed. Finding piston rings for these deisels is a bit tricky unless you wanna pay £200+ from VW
so after my holiday this will be going back together
pistons all cleaned up ready for the new rings
new rings fitted
the bore before the honing
then after a quick hone almost as good as new
heres a bit of a problem
the top of the block looks like this
but then the gasket looks like this
seem theres a few holes missing in the gasket and they are also not as big as the holes in the block
what you rekon???
Twitter Manager
http://www.jorily.com/catalog/index.php?main_page=product_info&cPath=132_109_110_126&products_id=1174
and my pic
