1976 Vespa Rally 200 Restoration - Complete
Hi mate,
what did they use to strip the paint and oil off and where they expensive
£28  for what you see
have a look at the website..  its 5 mins from my house
http://www.paint-strip.co.uk/
they can dip an entire car  8O
decided to take the frame to be stripped as all the seal had gone
yes you can get a vespa in a mk1 golf :D
all rust and paint will be gone soon! nothing will be hiding :shock:
1st pass at cleaning the engine, before and after
She will be a looker when you get here finished,but there is no rush take your time, all good things come to those
who wait ? :)  :)
who wait ? :)  :)
just the man I wanted to speak to.. read you thread and I'm after some ali clean for this project, didnt fancy paying £6 for delivery? did you pay for delivery? do you know of anywhere local that sells it
Hi mate, I paid for delivery but i bought a lot more stuff,if i am correct arnt Frosts based at Rochdale,
Thats not that far away from you.
cheers.. about £6 petrol away :lol:
think i will bite the bullet
10 for ali clean 6 for delivery :x
What do you think on the Engine casing..  Ali Clean, Ali blast, then does it need the clear coat?  it it ok at high temp?
is under hood black good at high temp too?  thinking of doing my cowl in it
Just had a look at the cans concerned,non give a max or min temp i only used ali blast on
things like water pump,dizzy,on things like exhaust and inlet manifold i used a high temp paint
and powder coated the rocker cover and sump.As for the engine block i used por15 again a high
temp paint.That all said the gearbox was done with ali blast and diamond clear laquer. Hope this helps
cheers andy…
got my frame back..  what do you think?  :D
HMMM :) its gona be a minter! Tony    hope its not for sunny days only when done :lol:
no it will be used as usual for work.. when i dont have a car space.(most days)
and also be more of a target for theives  :x
hope its another 35 years before it needs some attention again  :D
Hi mate,this is the first day i have been able to get on to the forums since the 12th,
Looking good so far when does the prep work start for the respray,and what have you
decided to do with the engine casing and parts.
The frame is still having some welding done, all the Ali Stuff has been blasted ready for painting
as for the casing I am gonna Ali Clean/ Ali blast, then is there a sealer/ laquer to use??
Did you check out if ali blast will stand up to the heat from the engine because if it dosent
then it wont make any differance what you put over it.
was thinking the actual casing in ali blast and barrel in something like por15.  gonna ring frosts this week to see if they can give any advice
welding and blasting
A bit of cleaning this evening(Ali Clean), reckon one more cleaning session and I will be there  :mrgreen:
Lookine good, Ali clean brings it up a treat doesent it,will you be at ultimate on sun if so
i will see you there.
Yeah its coming up well..  Gonna give it another going over soon.  Wont be at ultimate this weekend.  keep an eye on regional..  Mark oggy trying to organise a meet end of march
these are being refurbed as a supplier has been messing me about
and some priming has been happening
The swift progress is looking very good Tony this "scoot" is gona be swish 8)
