HT lead advice needed
Early-1800 said
Hate to state the flippin obvious but how difficult is it to remove and replace one at time so they don't get mixed up. :dontknow:
That is obvious! That's what I've done countless times before but in my moment if madness common sense went out of the window. That's what my problem was!
Anyway the AA guy was quite happy as he loved my car and seemed happy to help.
AndyT said
Right, got so fed up I called the AA as I've got homestart through my bank. Turns out I had them round the wrong way on the plugs. I thought that the cylinders were 1 to 4 from right to left looking at it from under the bonnet but no it's left to right.![]()
Had tdc correct and the leads correct on the cap. The engine was totally flooded so he showed me how to sort that by removing the fuel pump relay.
Anyway it's all sorted now!![]()
I did try and explain, a couple of times, how cylinders are numbered!!! All's well that ends well now though, good to see it eventually sorted.
To be fair though, you did make it confusing for someone with little engine knowledge!
It made sense to me, but with your constant references to different ways of viewing the engine etc, it could have got a bit confusing.
The easiest way would have been to explain that cylinder one is cambelt end, and that cylinder 4 is flywheel end.
I can't help but feel that you deliberately set Andy up to fail, by trying to overcomplicate things for him.
Take a step back Paul, and consider your audience. I'm probably right in thinking that you knew exactly what Andy's problem was, but you chose to skirt around it, instead of just explaining things in a logical manner.
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
I have to agree with that but do appreciate any help.
It just shows that one person's explanation can never be quite 100% spot on, so others who could have also replied should/could have explained it in a different way, or drawn a diagram, or labelled a pic, etc. Maybe they didn't do this because they felt my explanation was adequate at the time?
I can't blame paul_c for my engine knowledge being a bit lacking!
