new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
few more bits done and started 2day
welded pipes on short runner
,i need to angle it more ,ill sort this no probs
trail fit of the propshaft
those garden bricks come handy lol
riped the old rear axle off, and oh dear dam std golf is short as well ,what a suprize
then thought ill trail fit the rear 4motion axle ,and yes,,more stress ,i shorted it too mutch ,as i only tuck a outside measurement of the tyres ,forgot about the thickness ,,lol
as u see from the rear wheel,looks ok thow ,so recut and welded a bit more on ,
seems better
looks more like a skatbord then a caddy lol
just riped carpets out ,to fit the clutch pedal
looking as well as the propshaft will be up in the tunnel ,may have to partly mount the gear selector on the top
mk1
she should be a rocket m8 when finished  8)
Re: mk1
havent a clue wots going to happern or how it may run tbh ,,never drove one ,,,i carnt see it been any quicker then my type1 850 t5 beetle ,,,,this maybe a little better with 4wd instead of my rear wheel drive,,, :lol:
poppyg60 said
i have one pic then think about the steering rack and prop
http://img516.imageshack.us/my.php?image=enginebaypoaintedge5.jpg
Sorry to jump in here but what tie rods did you use with the MK3 rack.  I thought non plus rods would still be to long for the mk1 track.  I looked into shortening the rods but there not enough meat at the end of the rods to re-thread as they tapper down
Any help would be greatly appreciated
A
will mk1 ones fit/
Mk1 inner tie rods are completly dfferent.
unsure less then bud ,ive heard some use a renult clio p/rack with mk1 tierods ,unsure how true this it thow ,,, :roll:
just a quick homemade engine mount be ok with some weld and strenghers on it , so i can slighty higher the prop  for a few more mm to rise the sump lol
havent got mutch time at mo guys sorry
decided to beef it up a little more
well that ill do for that engine mount mount lol
next 6spd linkage needs to be started as
i mounted the propshaft right up in the tunnel
so remote will be welded best i can ,and i chop the cables to shortern them later,trail fit
Insane!!!  :lol: Are you the bloke that put a Volvo T5 engine into a beetle? Would make sense…
haha yep that was me…
best powerplant and power to weight ratio ive ever done ,not bad for a homemade rocket lol
few more bits done this after
centre prop  mount sorted
just started on mounting the rear diff and axle
prop too short lol  so ill soon sort that little joby out,,
not mutch to add untill i sort some steel 2moz ,,
started to weld nuts in for rear mounts and decided i wont it lower ,stress lol ,ill re sort this 2moz
only had a a bit of time as it were getting dark so made a quick restart on the short runner ,had to angle the box for the air flow ,which one day may be runing
 and found a stronger coilpack pack for better spark gaps 40,ooo ,instead of my 10,ooo one ,rough idea of how it will be wired lol
You are mad! LOL
Keep up the good work!
A genius is a person who successfully applies a previously unknown technique in the production of a work of art, science or calculation, or who masters and personalizes a known technique.
 :clap:
funk-star said
You are mad! LOL
any one could do it ,,,welder and an :D d hammer and ur away
 :clap:
erm right ,one way of putting it ,i pref hit ,wack,chop ,grind,weld ,next lump of steel,,,sorted ,lmao,,cheers chudd
 :clap:
thankyou chudd as you say im a genius :mrgreen:
man this is a balls out conversion!
love it
