new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
poppyg60 said
yep my engine exerts over 500lbft at the crank. If you can tell me the grade of steel the car is made from, I will tell you the tensile strength of it,
is that all if i add the internet torque to mine i get 600lbft at the crank :mrgreen:
tbh the only people that know the awnser are the people that have built them and from what ive seem they all make there own mounts
i made my own mount on my 20v which is better that the crap alloy mounts that came with the engine :wink:
to put a subframe in a mk1 is just mad youd lose the cars front end strengh by cutting the chassis legs out not sure why youd do it tbh more hassle than its worth
It depends where you weld it to and what shape the underlying section is too! This has reasonable data for the strength of welded steel:
http://www.msm.cam.ac.…se-trans/2005/LINK/58.pdf
Obviously the calcs would be to decide on a safety factor then determine the required thickness of the chassis leg, you could probably assume its shape is that of a plain box section. Then compare this to the actual thickness of a standard mk1's box section.
slight bollock i dropped lol ,one of many ,the external wastegate will need rechopping and moveing up the back,as i want to get the engine inline fr the drivshafts so i can make them fit ok,,supose it will be ok for a bit of track fun ,thinking about it might have been ok as a std lump without the blower ,ps that turbo is a mismatch ,but if my calucation is right ,it will work spot on for the amount of bhp i need .
yep seen some paul ,most are mk3 vr6 engines ,as i couldnt find too mutch info ,on the 4motion mk4 v6 24v lump been fitted with the 6speed and 4wd system in a mk1 caddy ,so i thought best thing build it up and thow it in to get an idea of how it would fit ,,,regards steel id sooner have strong thinker steel with a more weight then thin which may bend od rip off ,as some of the youtube vids runing 400bhp ,was fun as it looked like the engine wounded to jump out of the car lol,cheers paul ,any info is helpfull info..paul_c said
There's loads of info and pics on VW Vortex of guys who have done Mk1 VR6 conversions and strengthened various areas of the engine bay, based on where other previous conversions have cracked or split. I think 3mm would have been fine, 5mm is very cautious and is ultimately just going to weigh the car down a little more than it needs to be.
the top gearbox one is original mountimg point with modded mount as is the front snubber,bottom gearbox one is 70x70 angle cut and fabbed (solid)
ashtray said
alright mate? it seems to be coming on nicley here is my engine mount this is the tricky one.the gearbox one is original mountimg point with modded mount as is the front snubber,bottom one is 70x70 angle cut and fabbed (solid)
NICE ON ASH i know my mk4 block has the holes to do this idea ,i thought it were easyer just makeing std v6 mounts fit and add one under the gearbox and one infront of the engine,,as ive seen 4motion golfs runing decent bhp with a heayr car.body weight with no problems …..looking cool thow ash,going to see if i can use a power rack fit too.
the pictured mount is a standard mk3 vr6 they bolt straight on the 24v so it was used it looks like yours is gonna be done before mine too
I DO PREF THE THE EARLYER VR6 MOUNT SETUP TBH ASH,BUT I ANT GOT ANY SO STOCK ILL HAVE TO DO LOL,WELL DONT THINK ABOUT IT JUST CRACK ON ,,,IT WILL SOON BE WINTER ..ashtray said
yeah i got offered a ex TSR power steering setup but it was stupid money (?500) plus the fact i would not have an excuse not to let the mrs drive it
http://img516.imageshack.us/my.php?image=enginebaypoaintedge5.jpg
hi poppy ,well chuff me that look and seems to fit very nicely ,looks like a mk3 vr6 engine cradle modifyed in ,very cool,but the wishbones look mk1,mk2 ish ,,have u cut ur tunnel out slighty as i looked at mine last night ,and i reckon if i cut remove the the first part at the front off the bulk head it should give me enoegh clearance to get the prop in ,im going to try remove my s,steering and fit the later mk4 ad rise it a bit ,as the ends are longer it should still steer ok ,,all gess work really ,but that dose look inpressivepoppyg60 said
i have one pic then think about the steering rack and prop
WISH ID not started it now lol ,found more probs 2day playing gess work ,with the engine,its either sump hits the floor or rocker cover hits the bonett, or wacks the old mk1 wishbones then transfor hits steering then my bloody manifold wont fit ,so in all had a bad day lol,along with cutting driveshafts lolpoppyg60 said
you have to raise at least 2 " then start to bring in bump steer , with 400bhp+ it aint gonna easy to hold when you hit a bump , mines bad enough now i have to in 4wd mode all the time when thrashing it,
few pics
had to make it fit best i cud considering clearance issuise
ill get rack ripped of 2moz its going to be tight ,fitting inlet ,fan and rad in there and a incooler ,,,plus my dam manifold want fit ,so more chopping is needed lol
once racked moved sorted ,ill cut tunnel to suit
steering rack off
more tinkering to get prop in
bit of driveshaft shorting
bit of bending here and there ,and it will fit ,
