new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
mk1 golf - resto
mk3 polo breadie - daily banger
approx 200mile , few pics
you,ll notice how big that turbo is and how small ive managed to get the turbo hotside
ive had it nice and glowing too …
<a href="052-2.jpg picture by cannon0114 - Photobucket"><img src="http://i307.photobucket.com/albums/nn309/cannon0114/052-2.jpg" border="0" alt="Photobucket"></a>
mk1 golf - resto
well guys , ive managed to blow it
so looks like more fun to come ,,,,,,,,,,,
heres a pic
i really think im makeing good progress , as i can cope with a few blow pistons here and there:thumbs_up
s.p stage 2 high beam con rods with bigger arp 2000/7/16 bolts
next bargin wasnt far away complete set of wossnerr pistons 200 ,off ebay
pics here
well they have arrived look ok ,soon see what happerns after a spot of run in ,,
so i think its time for some serious boost what u guys think,,,,:thumbs_up
just not happy with arp bolt torque settings , contacted arp they said arp 2000-06 bolts are 40lb with arp greese/molly greese , might as well have used my fingers lol , sure they not going to hold at that poundage as soon as i get some boost on go they going to stretch and spin the conrod bearings
, started and runing no oil light probs ,see how things progress //fingers crossed
and she runs happy with idiol
http://tinypic.com/player.php?v=nmdruh&s=7
a few pics of cast welding… chop/modify
plenty off room with turbo and flange moved over
plenty of intake room too
needed to add a 46mm external wastegate , so welded that in too and made a screamer pipe (bit of extra noise )
welded inside too
got rid off that horried s bend boost pipe
need to turn wastegate pipe too
i might see if i can make a normal downpipe and remove the side pipe too
updated
not over happy but fits and works ,just wish i had more room to make a clyinder type
geejah said
Just seen your project for the first time and I'm blown away!!! 8O 8O 8O It's absofrigginlutely immense!!! You know if you get bored you can come and do my engine…I'm quite good with a bucket n sponge so I'll obviously return the favour :wink: Keep up the amazing work!!!
and i'm quite good at making tea and doing the mcdonalds runs, so you can do mine too
3inch v band buzzed on inside/outside
downpipe finaly done ,think my welding coming on too
then got grinder out and choped pipe to make a v pipe for the twin pipes
downpipe and exit pipes sorted next , make some side pipes[LOL]
stunning work, have you got any info on exactly how you solved the problem with the haldex rear diff controller, just starting to mount up my 4wd running gear into me golf and don't really wanna spend 210 euro on this controller,
http://www.sqsracing.com/produkt/314:406:haldex-regulator-controler-valve
Andy.
hi andy basicly looking at this all that will do is sit in place of the haldex so u can manual adjust the pressure , tbh its just a releif valve , ive tryed a number of ideas , first i used a bike cable (80p from bike shop and made it move the valve , then decided to wire the prime moter to a on/off button which primes the haldex for a while depending on ur pressure adjustment, problem is it will work fine this way if your just useing it in a straight line , but if ur wanting use this on the road ie ,and driveing around corners you have issiues as when the hladex starts to disingauge it will start banging and try locking the wheels , as i had this and first thought it was the diff or axle or driveshaft knackerd , as ull see a vacume pipe on it this instantandygall said
Hi mate,
Andy.
