new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
yep i did and yes from s,yorksmickeyone said
did u buy them injectors of me dude! sure your the guy from south yorkshire!
so that was thown in the scrap
next only thing i could do is modify the stock intake manifold but keep the runner lengths the same
ill just finish the welding 2moz and do of wireing unit turbo arrives
modifyed the breather and has a better idea with wire gauze and oil splash plate , which should help in boost , what a pain to alloy as the alloy contains very small fragments of hot oil and i assume over the years its contamiated the alloy , but got there in the end
fits a treat nice and air tight [
also saved a good 5inch , so means i dont really have to change the sump , but i think ill make a shorter one
removed the old sensor and filled the old hole up with alloy
lump of 3mm alloy then driled a few holes
then added a 5mm lump of rubber and bolted the coilpack up to the back plate
noticed i left a gape between the timing chain cover and the back plate , save engine heat on the coil pack and added the rubber to keep it cooler ,
injectors re wired, and all engine loom wires alterd , tempord to try a start up 2moz ,,be a tad noisey but should fire up
next as i have a bit more room i pulled the exhust side in around 2inch ,(saves a rattle
then new turbo arrived so thought might as well make a manifold , first tempory fit ,
you,ll notice its on a angle reason is ive no room to run a dam boost pipe , ive an idea thow lol
few start pics of the turbo and manifold progress
didnt like it above so alterd it lol
loving the car mate
quick engine video
View My Video
first had to chop the intercooler and weld 2 cores together and modify with pipe work , as the single wasnt cooling enoegh
then welded the lot together
somert like this
then nearly forgot needed a blow off valve fitting so welded that on too lol
you can just see it here
next hit a slight problem with the outlet on the boost pipe so thought chuff it ill make a s bend as to flow few engine shots at mo
keep us updated would love to see this on the road
Love the custom intake, vr bit!
Keep up the good work!
Pete.
cheers peteredpetemk1 said
As always excellent work!
Pete.
engines runing very well at 15psi at mo , oil temps, oil pressure, afr, timing, fueling map best its been so far ,, so thought id treat the caddy to another homemade header tank , made from alloy , as ebay prices are a dam rip off
think ill make a quick water bottle 2moz too ,, fills a hole lol
got a bit carryed away after making a header :laughing:
then decided to skim some alloy down and make a start on the new engine mounts,
standard ones fit sound as stock on the front heres a quick pic and no rim cutting needed
evern made a jig to re line the rims ,, unsure what to do , asi like how they fit on the fronts, as the tyes wount catch the archers when i slam it
