new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
8)
cheers its only a mock up of cut weld and get the buggar in ,,,maybe ok i supose
and a few more updates 2day
thats the manifold sorted at last
then made a oil return have to say what a little twat that was lol,due to havein to make it fit thew the bendy pipes
then thought might as well sort the steering rack ,and make some brackets
shes close but clears nicely ,and has a good 10mm underneath
thats the rack nearly sorted just have to make another bracket and trim the inner wing holes more a little more movement ,
right we have some seats and harniss ,to nicely hold me in place lol
thought might as well fit antiator and trail fit a few engine bits,bingo things seem to fit too
and thats 2days progress ended ,may have a few more after ive sorted a few other things out ,,,
cheers welsh itsacase of havin too when imoutside working alone ,with winter here,now if i had a garage ,it would still be sat there lolwelsh-mk1 said
The speed your doing things 8O . If everyone went this fast then there wouldn't be a mk1 needing attention left!
and added a homemade suport to save engine rock
and decided to make more clearance for the steering rack in the end lol
due to useing mk3 vr6 hubs and moveing the steering rack ,things arnt quite right yet ,but,,,,i will sort it ,,ill not be beatrn with it ,,lol
so had to fit more coilover springs ,
and a few more bits of welding to be sorted lol
right need advise on what radiator you guys use on a mk4 24 engine for cooling,as i could sqeeze the 4motion one in with lots of cross member chopping so thought id ask first
the size is 650x310x50 someone is knocking them out on eBay for ?139
hi ash cheers for the reply ,ive find this on ebay says rs 500 but the measure is slighty differnert and i neeed one with the water hoses on the same side like a mk3 vr6 typeashtray said
alright mate? looks like its going well!!! just a suggestion i used a cosworth RS500 alloy rad it fits perfectly with 2 small brackets with rubbers with out the need for any cutting these are rated at 500+bhp should be all you need!!!!
Dimensions - 640mm X 310mm X 52mm (Core Size)
cheers ben il have a look in scrapys may have somert i can use,,,do they fit into the front cross member as i didnt want to chop it outbens_cab said
mk2 gtd rads are big i used one in a mk1 TT conversion then appied to kenlow fans :wink:
crazyquiff said
I've got a GTD rad here if needed![]()
can you confirm its width ? it should be pretty much the width of the mk1 and use the outer lug holes on the cross member either end
rob
www.keets-customs.co.uk
had to make hole bigger so steering wil clear when wheels are let down
scrapy searching for longer arms to suilt the wheel track/use mk3 vr6 track ends more of a curve then mk1s
and a few bits of weldeing
bending 4mm plate on this chassi was fun,as i had to sure sure it was strong ,
sorted the clutch piping and slave too
the a quick repair on the rear quarter pannel
mk 1 cloned with a tt
Re: mk 1 cloned with a tt
nice one pal,,always good to see projects ,,,heres a couple morePoohbear said
interesting to see the variety of different mods, i am currently putting a tt 1.8t in a mk1 couldn't be bothered with all the patch on parts so it will see how it goes with the tt bits. :wink: will add some pics when shes ready!!![]()
couple more bits of welding this after
inner part of door piller
rear sill needed a lump welding in
bit sorted on rear quarter
then i was going to buy some more doors as mine were rottern at the bottom corners ,so thought id have a first attempt at it ,went ok i think
