new member mad idea ,mk1 caddy 4motion 4wd turbo 24v......
ouch…these arnt cheep for a old caddy are they ,,im affraid ill have to make one…like the restcrazyquiff said
adaptorman said
MOST OF BEDS NOT IN BAD SHAPE ,how mutch are they as it maybe cheeper ,welding some plate in?crazyquiff said
I can rebuild your locks and am planning to do a range of caddy panels - have a new bed in stock now![]()
?250 +VAT +p+p
Rich
cheer ill have to stick to the only way i know ,,,homemadecrazyquiff said
Will be doing a whole host of panels for the caddy soon. Again they won't be cheap :cry: but hey ho.
Rich
a little more done this after hopeing to have a full day it 2moz,,,
just the anti rool bar to sort and a driveshaft and thats the rear axle fitted done for the time been ..
added a few bars and welded a few things up
added a couple of strengthers
and thought ive just time to sort that rear rottern arch out ,
will look spot on once ground up and painted,,
also im a little un happy ,as i can gain a good 2inch lower now ,but because of the strengh of the mk4 rear springs ive fitted it wont sit as low as it should ,,,so its either thow some lowering springs on and adapt these buggers to the rear ,,nice air shockers lol ,adjustable ride right then,
a nice holset hx40w with 4inch in and 4inch out lol ,,,,,
yes its big ,may take a bit of fitting thow lol ,,,
so a trail fit is needed….these buggars will thow out 44psi ,,my aim is anything or 15psi to 25psi which is 500bhp on these engines
i reckon i can make somert for it to work lol
And 500 bhp in that thing will be savage, reckon it will all hold together?
Jimmey said
Arnt Holset turbo's for lorries and stuff like that lol ?
with all that box section? id say it will stay together
yes its off a big engine ,ie gas turbine etc ,,but as its going on a smaller faster reving lump ,it can tripple the engines lift ,just spools a little later ,and heres a compresor map ,,,it can run 44psi ekkk,i only need anything from 10/25psi which is 5oobhp ,,,well if it dont then i reckon i should feel it ,,,,,rumble rumble bang ,i know the runing gear is strong as ive seen this setup run from 200/700bhp thew them ,mental,,Jimmey said
hi rich ,tbh ,im runing another welded drives same idea on a 300bhp ,shoveing over a ton ,and shes had a fair amount of track pull ,never had a prob and thats 2wd ,,plus the big turbo wont be as snappy as the small one so that ill save shearing gearboxs,drives,clutchers etc ,plus ill be makeing differnerr manifold so the turbo spools a bit better and just got the compressor map ,,crazyquiff said
Might want to sleeve and weld that shaft - If you cut the sleve on an angle it'll be stonger too.
Rich
not really mostly common sense ,yearh just rip into it lol out with the old 1.6d/4spd/rear leaf spring 2wd ,and fit the 6spdv6/24v turbo /4wd system lmao,,,,was funny 2day ,had a a frame fixed to caddy and went for a tow up road with laptop and web cam checking for faults ,lol no funny wobles ,and nought fell off ,,,lolcrazyquiff said
That's cool - you've obviously thought about it and have the experience. Roll on the 4WD - love your get it done approach.
Rich
and started on makeing a pulse manifold to help spool my big turbo up ,
keep on dubbing
its nothing to droll about at mo,until itslooking more solid with a few bits on itgaz_mk1 said
hi mate dint no you was from doncaster wear abouts are you and can i come and have a look at this beast and droole over it for a while lol. gaz
i offered to help because i dont no anyone in donny who's in to vw's need to get into the comunity.
keep on dubbing
ill need a complete lock set some idiot nicked my keys ,unsure if yove a pair of decent doors mine are rottern think 4dr fit/and a wiper moter lolgaz_mk1 said
bean a mechanic the parts lying around and the putting it all together is more interesting than actually seeing it finished a no am weird lol if theirs any parts that you need like wings and stuff just gis a shout as iv got like three mk1's worth of parts all over ma house, garden and attick lol
bingo thats that bit sorted ,and i have to use a 44mm wastegat too as u can see the larger pipe
this is how to make one
just the other half to make now
