MK1 20vt Megasquirt v.335
hmm
the best bit is you are not limited to what mods you do cos you can alter the map so if you want bigger injectors turbo ect ect a few years down the line its not a problem just remap the car
oem is good but you have to keep the maf the coilpacks these are the bits that make a 18t unreliable :wink:
lol
as for the laptop a cheap ?50 jobby of evil bay would do it as long as it has a serial port on the back :wink:
ta mate!!
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
try that it will look very um involved but most of the stuff it says to do is already in the base map so all your be doing is checking tha afr and timing ect once running :wink:
paul_c said
Ben, how did you set up your ignition map to be optimal? Are you using extra hardware and the existing engine's knock sensors? Or did you simply take a guess at the settings and advance a little bit more until you heard it knock?
i didnt use the knock sensors as at the time megasquirt were still in the testing stage i do believe now there is a system called knock sense that can be built to intergrate with the ms i think eddie is in the process of testing this
with my spark map it was a case of listening hard for any pinging then we adjusted the spark and fuel map until this dissapeared this was done originaly with no boost so running n/a then increasing bit by bit until we were at the desired amount
mapping like this works best up steep hills and under load in a high gear at low mph
trust me when i say you know when youve got the slightest of pinging on these engines :wink:
heres some pics
donor car:
guna give it a steam clean tomoz and see how it comes up!!
the coilpack will wire into the pins that eddie fits the vb921s to pin 36 or 37 is spark A and B will be on one of the spare pins :wink:
but it does staret on the button first time and runs really well with good boost, i drove it up the lane outside my work when i got it back and it pulls really well!!
what the vb921s??????
