Which outer CV joint do I need
I am in need of replacing the outer CV joint on my mk1, and there is 2 different types available on vw heritage.
I have a 20vt conversion with the larger 92mm inner flange, does the inner CV joint size effect the outer?
Sorry I reckon its a 98mm inner flange, required for the conversion.
I just did mine and chucked my reg on eurocarparts. They sent the right one.
I know but the driveshaft and inner cv are different with the 20vt conversion, so not sure whether I need a different to the original for the car
They are either 100mm or 90mm.
You need to measure across the widest point of the CV to see which ones you have. Probably 100mm ones. I am not sure if you can mix and match 90 and 100 ones on the same shaft.
100mm ones will bind on 90 hubs, but you can clearance the hubs quite easily
Cheers,
Ade
It's the outer CV joint that I am need of though. Does the size of the inner joint alter the outer?
Yea, each end is increased to 100mm, hence the huns being different
Cheers,
Ade
With the 20V T conversion, you use 100mm late cabby drive shafts, I'm guessing you would use the correct outer for a late cabby, no?
indeed as the man says, late 100mm gti cabby/rocco shafts = late cabby/rocco 100mm gti outer cvs. if it helps they're same as mk2 gti :)
Alright lads, Ive been and got the CV joint in the link today from eurocarparts for a late cabby.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/car-transmission/transmission-parts/cv-joint-kits/?657443251&1&c8dd660c1edd04a80507726b78bc78824b2d731f&000095
The spline and hub dia match up, but the overall size of it is alot smaller, my outer dia is 90mm whereas this is around 80mm. The boot is also to fit a smaller diameter driveshaft.
Can you help me which one it is that I need, as this was for a late cab.
Cheers!
yup that should do it
