my modified campaign project.
Last edit: by abfmk1
DSCF2248.JPG DSCF2247.JPG DSCF2246.JPG edited
 Nice painted wishbones, with new ball joints and rubbers, and a nice rust free pair of rear w/bone mounts with new clamps ,  and new stainless wishbone/ antiroll bar mounts
Painted up original strut housings, new/unused febi top mounts and new/unused bilstien b4 inserts.
 The unused so far,  1.8t engine and 02j gearbox conversion mounts.
Cabriolet 100 mm hub assemblies, derusted, painted and new wheel bearings inserted
New rear B4 bilsteins with new bump stops and used springs..
DSCF2301.JPG DSCF2299.JPG Used ABF flywheel with new bolts and new vr6 clutch assy to replace standard 1.8t flywheel assy. Usual recomended conversion.
Used pair of 100mm driveshafts
New unused steering rack with new unused steering arms ( i planned to put an adjustable arm on both sides ) and new unused rubber gaiters.
Modified brake cross over linkage to allow fitting of clutch master cylinder..
New/unused 16v type cambelt tensioner and new/unused epytec spacer. These are needed as original 1.8t tensioner fouls on the modified mk1 golf conversion mount, and needs removing.
DSCF2318.JPG .
DSCF2320.JPG Audi tt exhaust manifold as it takes a K04 turbo, and a new/unused K04 turbo (chinese style)
Engine / gearbox in
New unused intercooler,  which i will not fit at the moment.
  edit
