My mk1 - ex Impact/Dubsport car
HCL isn't mine but I know the lad who owns it now. Pretty sure he's putting a 20v in it because it came without the G60 motor
Edit
Managed to fit the engine last night without using a hoist. Basically jacked the car up, walked the engine into the bay, lowered the car around it then climbed in and lifted it up while my mate popped the bolts in.
Last edit: by MR_LONG
No huge progress but have managed to get the driveshafts in - this took a while because I literally got them all bolted up then realised I'd forgot the washer things on the flanges.
The turbo is temporarily bolted up untill I get some aero locking nuts and I've trial fitted the rusty downpipe which I think I'm just going to have to put up with untill I can afford to get a stainless made up.
Its going to be tight getting the inlet side of the turbo sorted
Oh and painted my wiper motor to realise that when you bolt it up its pretty much hidden - DOH!
MK1CRAZY YAHOOOOO!!!!!
Matt
I've managed to extend the loom and get a few other bits and pieces on the G60T done including getting it to run after quite a lot of head scratching (turned out I had the dizzy out by 90 degrees - still don't know how)
The next jobs on the list are to get the cooling system plumbed in and sort out the intercooler side of things……
its highlighted a couple more spots that need repairing and that the passenger side chassis leg has been half replaced in the past (not the best of jobs)
I managed to get hold of a second roof support and have got that welded in now. Just need to paint the underside before I try fitting the roof (not looking forward to that)
I've bought an intercooler and been working out how to mount it using some of the original holes in the front panel. A simple piece of aluminium angle, alloy tube and some bolts should do it.
And I've finally mocked up my boost pipes so thats the next thing to order. Not a million miles away now.
I finally got the roof fitted at the weekend. I was going to paint the braces etc before hand but ended up with overspray all over the outside (still got to clean it off) so thought it would be easier with the roof on.
Here it is with the sikaflex applied
And then all taped down
Then came the painting of the inside
Theres still a little finishing off to do along the gutters but its another job closer to getting it on the road
Matt
My red hoses and lengths of alloy pipe turned up the other day. First I had to get the fitting for the C02 sensor welded in (took it to Advanced Radiators in Scotswood) and then had to try polishing them up because the straight lengths didn't match the polished elbows. They're not as good but not a million miles away considering I just wet sanded them and finished with some autosol
Just need the brake & clutch lines sorting now before its MOT time
Oh and couldn't bleed the calipers for some reason so eneded up fitting some Audi Coupe calipers I had (now 256mm dics)
Next on the list is to get the carpet cleaned and fitted with the passenger seat and some rear cards for the boot and a new 2.5" exhaust on the 13 May
matt
