AT LAST! Hairys Resto!!
Web Team
1983 1100 C
1983 1100 C
ew said
Coming on nice, a little more rot than you was expecting?
maybe just a little!!
Hope to be tucked away in the garage Saturday putting it right! 8)
..had repair section zinc primed and ready to go on
First bit of welding - the brake hose bracket had just dropped off the repair panel so I welded it back on… (Not too many grapes!!)
Went to weld repair panel on but it needs a good hammering in to shape and it was getting too late (don't want to annoy the neighbours)
Not got too much time to play tomorrow but hope to get the panel welded on, seam sealed and rust primed.
Will make a refreshing change to be sticking bits back on!
Also if you grind the welds, although they are less strong, it can remove areas unreachable by the wire brush, therefore making it last longer even though its less strong. Unless your welding's better than mine and you can produce neat stuff without any blobs, etc at all!!!
I tried to get the repair fitted and welded on, but having issues with the MIG (See HERE)
Then just as I seemed to get somewhere I ran out of gas
Away next weekend so that's it for now - think I may just make up my own panel now, I've had enough of this Hadrian one
Rant over - and breath!! :wink:
If it is really that bad you might be better to cut the repair panel into a couple of bits and weld it on in several pieces. Sounds like you got through your gas quickly, sure you haven't got a leak in the connections? If you're using disposable bottles, machine mart do a good bottle for a bout ?8 with 20% free. Get a couple as nothing as bad as running out of gas on a sunday.
If you're lucky next time you might get to perform the welders dance -that's when a bit of hot metal goes down your jumper or sleeve and you dance about furiously trying to shake it out
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
That repair panel looks rubbish - the ones I have are much smoother without all that creasing you can see in your pic.
You can see a pic here http://www.golfmk1.co.uk/PatternPanels.htm
Fitting panels in this area - what I do is get the holes lines up first on the studs and bolt it up. Then to a couple of tack welds - don't worry too much about the fit. Then hammer and weld as you go to get the fit right. It'll be almost impossible to get the panel fit right off the car.
Rich
chudd said
only a mm or two gap but enough.
It's a rough repair panel , you have to fettle it , roughly .
You are learning and doing well keep at it :wink:
Cheers………..
..That gap was after a LOT of fettling!!
could always try a little heat on it to help bend it into shape
paul_c said
OMG!
Got this far…
…and then damn gas ran out
Anyway, picking up a bottle from BOC tomorrow so can then get it finished. Hope it doesn't take as long as the resto has so far
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
jamiegolf said
thouse white gas bottle's havent got a regulator on them!! thats why your using so much gas!! if you get a bottle from boc ask them if they have a regulator to fit on the top too, the little bottles are a total waste of time!!
Regulator and tube/adapter for the bottle is around ?60, BOC will have them (but they might be more costly than that). I found a specialist welding supplier shop not too far away and took a visit, no doubt there's cheaper options (eBay springs to mind) out there.
1983 1100 C
1983 1100 C
