AT LAST! Hairys Resto!!
I've got one nut loose now (Yippee! :cheer: ) but the others are so rusty and rounding off will need to look at nut splitter. Went to Halfrauds to buy one - they only had one left and it was already broken! :evil: Also went to buy an M10 die nut from a local tool supplier. They wanted ?36 + VAT! 8O Fortunately, borrowed one off a mate. It's helped to tidy the threads up a bit, will use it when the nuts are off.
Thought about using heat but just a tad dubious about using the blow torch near the fuel pump! Oh well, getting there - will spend Saturday on it and hopefully get the rear end stripped ready for cutting and welding!! :twisted:
Finally, here's another pic - of my rusty bottom - as opposed to my hairy….!!
ENJOY
I've got one nut loose now (Yippee! ) but the others are so rusty and rounding off
I remember that feeling of triumph when the first one came undone
1983 1100 C
1983 1100 C
Chassis legs not too bad - drivers side is the worse
You can see the gaping hole at the end of the sill! The other side doesn't seem so bad.
Thought I'd be welding today but took longer to strip all than I thought. Forgot I had braided hoses on the back so no flexies to simply cut - I wanted to keep these as in good nick, so spent a fair bit of time stripping everything off, then got rear beam off.
It wasn't until I dropped the beam on the deck I realised my axle stands were in the way of just sliding the whole assembly out from under the car
Filler neck came off without need to unscrew - as you can see, a tad rotten!
Hopefully will get some more time on it tomorrow - will finish stripping interior, take out rear side glass then remove the 'over sill' and see the original lurking under and what rot is really there?! 8O
Anyway, that's it for now - just a couple more pics of my lightened rear end! :wink:
Life Member
I finished stripping the interior out completely (spare bedroom is full with seats, dash…..) and made a start on removing the 'over-sill' on the drivers side. Those who know my car will remember this unpainted panel :wink:
Unfortunately, the only thing the previous owner did well was mask the spot welds so its a bit messy now having missed with the spot weld drill bit a few times
The sill isn't even welded at the front - held on with silicon sealer!! 8O
Doubt I'll get to finish cutting this off until the weekend now (can't be making too much noise late at night and annoy the neighbours :roll: ) Just need to be careful cutting the sill off as they used the whole panel, slapped over the old. I can't cut away too much of the original or my new one wont fit!
Finally, took arch cover off 8O Rear off side corner is WELL rotted out! There was even a 2p piece in there - taking it out has halved the value of my car
Need to find some quieter jobs to do on the car at night time now…
1983 1100 C
1983 1100 C
I have my eyes peeled for the right car to get back in the Mk1 porn fest sceneryism.
All I have to do is sell my T25 camper!
I soo regret selling my old car.
Gareth
1983 Y GTI Black
1983 A 1.1c faded pink (Sometimes described as mars red!)
Mark - sill on the other side is original. May need a little 'fettling' but no where near as bad as drivers side
Inner sill looks alright so far (No pics yet!) Just wanted advise if it's worth laying on some hammerite or similar or just leave it and plenty of waxoyl when all is finished??
I'm going to start work on my inner arches soon. Cleaning and re-coating a bit. Sorry if this is a stoopid question, when you say 'Hammerite' the sills, what is the hammerite product. Primer? I think I should use some for the flakey paint bits.
whatever you do, DO NOT use halfords antirust primer, it doesn't work at all
Personally, I'd go for a weld-through primer and red oxide primer anything that won't be welded, then hammerite + wax oil should keep the nasty stuff from coming back
dubhighland said
my campaigns reg number is sys aswell , do you know what area the number is from?cheers
Check out http://www.right-reg.co.uk/number_plates/issued, which I found a link to in this thread
HTH
Rich
what a great site, SYS is a glasgow number and my lhasa is from manchester. cheers
Just to confirm what you now know - my car was supplied by a dealer in Glasgow
