83 Gti set to get full resto
My 83 Gti set to get full restoration
When you drop the old wheel well off and before welding the new one on make sure you scrape off all the old underseal on the underside of the boot floor. (I assume you are renewing the under seal)
I found it really difficult to get in all the corners of my boot floor with the scraper because the wheel well and lower valance was in the way which limits the amount of angles you can attack the underseal from with the scraper.
Good work on the chassis rail
Phataz1 said
With regards to removing the wheel tub, the chassis rails that you have just welded in along with the rear beam mounts will hold the structure straightSo the shell shouldn't move in any way. But if you're still worried, just make sure that the shell is supported on that side, either end of where the tub would sit. So somewhere near the back of the sill, and the rear-most jacking points under those new rear chassis rails.
Cheers for that Phataz1, I thought that might be the case, I just like to make sure as I've never worked on a car before lol. Learning all the time though!!
Cheers, Andy
Yomp said
Just a tip from when I remember stripping my old underseal -
Good Idea Yomp, in-fact you've just give me another idea, I think I'll remove the spare wheel well before I start the tub so I've got another place to stand. I'll just stand in the hole where it was lol. I will be fitting a new genuine rear panel once the car is back on axle stands, so I've already cut the bottom half of the valance off to ease access.
I love this forum man!!
I was and still can be exactly the sameMelteddrummer said
Cheers for that Phataz1, I thought that might be the case, I just like to make sure as I've never worked on a car before lol. Learning all the time though!!Phataz1 said
Cheers, Andy
So aside from cutting out an entire side or end of a mk1, it will never move out of shape
Here's some pics
Here you can see the new chassis leg running under the boot floor.
Out with the old and the new ones waiting to go in!!
Cheers, Andy
borednow said
wow.
I can see why you're saving it. The scrap man wouldn't have given you anything as it was all rust
Inspirational stuff mate.
E![]()
Cheers mate. Yeah, there is/was plenty of rot to have a go at, getting there now though.
Cheers, Andy.
Matt
Yeah Cero, it definitely helped getting the tub out tonight. Still got the o/s tub to do too, if Heritage ever get any more in stock, that is!Cero said
Andy, good idea about leaving the wheel well out, that way you can sit inside it and weld to your hearts content, that's how I did mine, but I had both tubs to do and a floor ! Takes me back ..
lobbers said
Good thread mate just read all of it looks like mines pretty much same. Just about to order panels for mine and cant decide where to get them from, do yours fit well?specialy the front wings and where did you find a spare wheel well ive searched everywhere. Keep up the good work
Matt
Hi Matt, I bought all of my panels from VW Heritage. I've done a trial fit with the wings and they seem ok for now but I haven't tried them with the doors back on, I reckon they'll need a bit of work to get to fit properly, but after everything else it will seem easy I guess lol
With regards to the wheel well, I got really lucky, I posted a 'wanted' ad for a quarter wheel well and a member on here had a whole wheel well for sale. My guess is that there aren't many around
Let me know how you get on mate.
Melteddrummer said
Matt
Hi Matt, I bought all of my panels from VW Heritage. I've done a trial fit with the wings and they seem ok for now but I haven't tried them with the doors back on, I reckon they'll need a bit of work to get to fit properly, but after everything else it will seem easy I guess lol![]()
With regards to the wheel well, I got really lucky, I posted a 'wanted' ad for a quarter wheel well and a member on here had a whole wheel well for sale. My guess is that there aren't many around![]()
Andy![]()
That was abit of luck. Sounds like those panels should do the job. Keep the photos coming love to see how people attack it
AaronGTI said
Great read so far will be following this thread, great fabrication skills too! Hats off![]()
Cheers mate
smudger1980 said
Awesome work drummer. Credit to you for putting in all this work. I think most would have sent her to the scrappys.
Cheers Smudger, it's reading threads like yours that's keeping me motivated to get the job done!!
Brad. said
Strong work man!
Cheers Brad.
On a side note, look what I've got sitting in the lock up…
It was never meant for this car and I may still not use it, but it keeps looking at me lol.
