83 Gti set to get full resto
My 83 Gti set to get full restoration
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
I managed to get the stripped down a bit further. All the wiring is out and the wings were removed and binned.
Engine is out
Bulkhead Repair
Here's a pic of the engine hanging in my newly bought crane, must say it's one hell of a tool! I also managed to source a new drivers door for £50 which is in good condition, mine is rotten inside and out and would have cost too much to repair. You can see in this pic the limited space I have lol
That's about as far as I've gotten so far but there's no hurry! My car goes away at the end of Jan for resto so plenty of time to get things sorted.
Next on the 'to do' list is to remove the fuel tank and lines and all brakes, apart from the handbrake and she should be just about ready for the restorers
Also been buying a few bits and pieces ready for when she comes home.
New lower arms with Powerflex bushes
A few more bits, got stuff arriving weekly now lol. Also got a shed full of body panels waiting to be fitted
That's about it for now I think, I'll update more when I get a chance.
Cheers, Andy.
As previously said label absolutely everything and good luck with the resto!
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
My restoration project will be taking a different route from now on. I've managed to get a decent size unit to work on my car out of the weather.
I originally planned to have the metalwork/welding done at the restorers, this was always nagging at me because I'm a steel fabricator by trade and I reckon I could do most -if not all- of the fab work myself, I just had nowhere to do it.
The money I have saved for the welding work will be now spent on rent for the lock up and some welding equipment, RESULT!! Once the welding work is completed, I'll take it to the painters to finish off.
Well I have a bit of an update. After removing the engine, I started to strip it down ready for the clean up. Going to be replacing all gaskets and seals.
Removing rounded bolts
Half way through stripping the engine down I ran out of room so I decided to hurry my a**e up and get the car to my new unit.
Next day I got the key for the unit and quickly got a bench made up and got some stuff moved in, FINALLY, I have some room!!
Here's my car in her new home, loving it! I was down the unit yesterday and got loads stripped off the car. All the running gear has been removed, just the glass, gear stick, fuel lines and a couple of other things to go now.
Hopefully I can get my roll over jig made at work this week and get started on the body work. I also found some issues in the O/S rear wheel arch,
I'm still unsure of what bits to order to repair this section as I don't know the names of the parts lol. Am I right in thinking that its the 'rear chassis leg' to the inside of the arch? If so, I need a new one for here.
It feels great to finally make a bit of progress, that's about it for now though.
Cheers, Andy.
I'll look forward to updates
92 caddy, Now stripped for full rebuild
83 golf gti R1 carbed 16v(soon to have 1.8T)
07 Leon FR TDI daily
Cambridgeshire regional host
caddyrage said
You'll find the repair panel on vw heritage mate. Hope you have rotisserie cause it ain't fun grinding and welding on your back lol
Yeah found them last night and ordered them. With regards to rotisserie, I'm making my own at work if I ever get a minute, hopefully have it by the weekend.
Managed to get a bit work done today. Got the fuel lines and the glass out and smashed the windscreen in the process lol.
I then got started on the bulkhead repair, had to cut quite a bit out as it was rotten. I bought a repair piece off ebay which was too small for the repair so made up a surround for it and welded it in place.
repair plate
welded in place
here it is from the inside
Not too bad for an afternoons work. I also have to re-fit the wiper motor bracket as it had to be cut away with the rest of it.
Andy.
Next I removed the old front panel, cleaned everything up and done a trial fit of the new one. I must say that the fitment of the VW Heritage pattern panels is not bad! The O/S needs a little bit of work but nothing major!
I then move on to the N/S sill. Removed the old one to see what was hiding underneath, tbh its not that bad really, just a few repairs to be done. Here's a couple more pics to show what was hiding,
N/S front Sill
N/S rear of sill
I also found the leak into my scuttle area, coming in from the top of the N/S wheel arch
So all in all, there's a fair bit to do but what I thought was going to be a daunting task, is turning out to be really enjoyable. I'm just going to continue on the N/S of the car and work my way round. After the sill, I'll be moving on to the rear wheel tub which I'm guessing, I'll have to make some sort of jig for? My plan( not sure if it's right) is to make a brace across the top of the turrets using the top mounts from the suspension and some 50x30 box section, then sprag off from the brace and pick up the rear bumper holes in the boot and maybe pick some other holes up in front of the brace somewhere. This way I'll be able to use the same jig for both sides.
If anyone has changed their wheel tubs before? any help would be appreciated!!
Finally a couple of pics of all the panels I've been collecting over the past few weeks lol
That's all for now folks. I'll post up some more tomorrow after another session!!
Cheers, Andy.
looks like you have a new mk1 from VW Heritage haha
Andy.
Andy.
Last edit: by Melteddrummer
Now we get down to the nitty gritty. I made a start on the N/S rear chassis which is completely fubarred
Here is what's underneath, cant believe this is what the rear axle is mounted to
In my wisdom I forgot to order the chassis leg repair plate for this side
Anyway, I started the patch(or so I thought) repair at the top of the N/S inner wing/scuttle area. This:-
soon became this…
From the inside..
few more of the work in progress…
I also found some rot on the 'inside' of the 'A' pillar. How the hell do I repair the inside of here??? any help would be greatly appreciated here please
That's all for now people.
Cheers, Andy
I have a golf which is mainly rust free and just needs painting yet i just cant be bothered to prep it and here you are saving a mk1 which some would just send to the scrapper.
Hats off to you man,
Mk1 golf GTI 1.8 - bargain buy
Suzuki Samurai - 4WD 1.7 TD Conversion - Off roader
