engine swaps?
engine swaps?
ramm said
basically, what's the difference between GTI and G60 engine??
G60 is supercharged. Also the bottom end is stronger/better lubricated, to cope with the increased power.
ramm said
could you give me more details (and horse power pls) between these engines:
1.8 GTI 8v
1.8 GTI 16v and
1.8 G60 /1.8T
112-140bhp
139-170bhp
170bhp-230?? (G60)
150bhp-280?? (1.8T)
16v would need fuel lines re-doing, to the other side of the engine bay; a new bracket for the fuel metering unit; relocated washer bottle; wiring changes.
Dunno about G60.
1.8T would need extensive wiring changes/integration of the donor car's wiring, since it uses an ECU with an immobiliser linked to the ignition key.
i got another question about this engine swaps
i got mk1 with 1600cc engine in it..
what would be the best engine to put into with the most less changes required??
maybe i'll swap the engine with the biggest cc possible without reconstruct the engine bay.. then after than i'll only need to change the engine components such as cranks, cams, n pistons.. so which engine will suit the best??
there is another question that i'd like to add..
basically what the difference between 8v and 16 (put it the same cc).. is it the power, torque??
the basic info that i know between those are, 8 valves and 16 valves.. the 16 valves has more high rpm power..
does 8 valves have more low end power??
thanks
It depends on what facilities and money you have, really. For some people, the fun comes from swapping and changing lots of stuff, to get it just so. What seems like a major burden for one person, is another's hobby!
Mk2 VR6, G60 CABBY
This is what i am hoping to put into my mk1 driver! A 1989 RE1900 16v and to be honest i cant wait. it was such a rapid thing in the mk2. overtaking was effortless and once you got to about 3500rpm pow it was just a surge of power put a smile on my face every time.
i need to start collecting alot of parts.
I understand alot of stuff will be needed from a mk1 gti like fuel pump, steering rack, wishbones, fuel tank and lines?
Does the mk2 Master cylinder fit the mk1 aslo what about the rear disks? i would prefer disks all round.
It's all horses or coures I guess, but I do enjoy the way mine drives… I'd like to try the bike throttle bodies route that Matt is trying too though!
I (personally) think that there is a point where you need to appreciate a mk1s limits before you've chased power too far, more power needs more traction, so wider tyres which mean you loose the nimble feeling a standard mk1 has, you also need better brakes to stop a more powerful car, bigger brakes need bigger wheels which again spoil the feeling of a good mk1. It's all personal I guess though :dontknow:
golf_coupe said
20vTs-takes summit away from the soul of the car imo, i always imagined my ultimate mk1 as being a tuned na engine with instant grunt and no crazy traits of running a 4000 brake turbo which jumps lanes when its finally wound up the turbo(i know a standard 20vTs nothing like this im running one albeit in the mk4)and i know its easy enough to bang a 180 20vT and then tune it but just cant see myself in a mk1 with one fitted
From “engine swaps?”
8 years doesnt half make a bit of difference to this answer lol
