DX to ABF conversion wiring
I also heard the click from the little black box when I switch the ignition on, although no additional click when I attempt a scan even though the cable light is on…
Stumped….
I assuem you have gone thru the port setup in vagcom to see if it can see the cable at least
Should diagnistic connector grey go into box then out to ECU?
Yes, Vagcom sees my cable and port correctly. I'll try it on my van as it used to communicate with that, but I had the old 409 software then.
The question is whether I try and sort it when I get home tonight after putting several beers inside me….
Thanks rubjonny. I'll sort it first chance I get.
Ill leave that for tomorrow night now. Hopefully the diagnostics will work
Thanks.
http://www.clubgti.com/showthread.php?199583
Sweat!
Thanks for all your help getting me this far rubjonny.
Regarding the Lambda. LS03 or LS06? I know you said LS03, but I contacted the seller of these LS03 universal ones, and they said I need LS06.
Do you know what the difference is?
LS06 will prob work fine really, just take slightly longer for the lambda to fully warm
edit: and yes, VW did make MK3s without cats in some countries
and by doing this I have managed to wire up my abf in my 88 dx gti.
and it fired 1st time once I put the live on the correct pin 🙈.
great work by the rubjihny. I have a few little niggles but very close.
Many thanks again all the way from New Zealand.
