DX to ABF conversion wiring
The coil was fine on the donor car, I have spark too. The fuel pump primes on ignition then nothing.
if you dont see a fuel signal when cranking i would suggest crank sensor, but you need to figure out where the short is to fuse 17 first.
mk3 coils are ok when they work, but they fail often. plus if you want your rev counter to work you have to open it and run a wire to the -ve terminal inside, with the mk1/2 coil it works off the -ve spade same way as factory mk1/2 engine
I don't currently have a rev counter, and besides, id just be happy with a running car! ha!
how am I finding the fuel signal?
for curiousity I stuck a 15amp in no17 and it wont blow that, I know that doesn't solve the issue though,
the fuel signal is from the ecu, if it primes then you know the wiring is ok and the ecu is powering up. but if its not runnign while cranking then the ecu isnt happy to start the car, normally this would be due to duff crank sensor. if you didnt put a new one in when you built the car then now is the time!
http://www.vwsonline.co.uk/car_parts_bristol/037-906-433a.html
whats hard to do is pin point anything in particular considering its not like it was running and now not, there could be so many contributing factors
where should the immob be getting power from? the red is going to d2?
it could still be the crank sensor even if it looks ok, trouble is no way to test them really sometimes even vagcom cant help you with it
im thinking about double checking the wiring for all the splicing or don't you think it would turn over at all?
