Golf 1,6 GTi Fuel distributor
(In Topic #240537)
I need a replacement fuel distributor for my 1.6 GTi EG engine
Original is 0438 100 059 which is 160cc/min full load,
Does anyone have a list of compatible units?
Dave
Regional Host NE
it's the 3 bolt fixingnicci21paul said
is it two or three bolt fitting mate
Regional Host NE
I bought a rough one with the correct part number off eBay, stripped, cleaned and rebuilt. Running like newbacardincoke said
I noticed you quoted the flow rate for your particular distributor… over the years I've read different figures mentioned for various ones, though it's always difficult to know if they're all 100% accurate.
If you had a reference to where you got yours, it would help towards supporting any others I might come across and build up a bigger picture… cheers.
I managed to get a copy of the Bosch micro fishe test specifications for the Golf GTi EG 1.6 engine and also have a few more Bosch reference guides.
From what I can workout the flow rates are:-
0 438 100 059 & 0 438 100 005
Setting Max Allowable
Idle 6.0ml 6.8ml
Part Load 40.0ml 44.0ml
Full Load 160.0ml 175.0ml
0 438 100 079
Idle 6.0ml 6.7ml
Part Load 40.0ml 43.0ml
0 438 100 100
Idle 6.0ml 6.6ml
Full Load 110.0ml 120.0ml
As mine had an 059 from factory it not run with a 100 as it was too lean on higher revs.
The 059 and 005 seem to be the same.
The 059 and 079 are so close that there would be no noticeable difference.
From the Bosch main site I found that the still remanufacture them and give the following as equivalent
F026TX2026
0986438023
0438100023
0986438079
0438100079
0438100059
0438100022
Also 0438 100 005 should be the same.
The main thing to ensure is to set the pressures from the WUR working correctly and spot on.
Also I have noticed that sparkplugs make a big difference to the smoothness at idle.
With NGK iridum plugs the idle was good but slightly lumpy/poppy,
When replaced with Bosch the idle was smooth with no vibration or lumpiness.
Both sets were new and of the correct heat rating so I am only going to use Bosch from now on.
Regards
Dave
