GTI Mk1 1983, does a MotoMeter instrument cluster have the L shaped circuit board for low oil pressure & buzzer please?
(In Topic #225360)
As per the subject line does the MotoMeter cluster from a Mk1 1983 Mk1 Golf Campaign have the L shaped circuit board that triggers the warning light & buzzer please?, I have the cluster out already but wanted to check before I risk breaking it by taking it apart just to find out that it doesn't have it.
I'm hoping that the issues are just dry joints on the circuit board as I've read this can be a cause, if not is there a usual component that fails or can complete replacement boards still be sourced?
Are there any tutorials as to how to disassemble an instrument cluster to get to the L shaped board?
Mods, I didn’t join up just to post a question, I was a member before (TonyP) but couldn’t remember my password & I never got the password reset emails.
Website Manager
So are you saying there is a similar L shaped board within the MotoMeter cluster that's also prone to giving similar faults to the VDO one?, I'd really like to know before I pull this cluster apart.
Re username merging, potentially yes please, but (a) I don't think I was very active as TonyP & (b) I still wouldn't know the password for it as I never got any password reset emails to the original email address for TonyP.
If it's possible to merge usernames TonyP & lazymogs but keep the email associated with the lazymogs username that'd work
Website Manager
My own experience of swapping the two branded boards over was that it did not work - this was on 16V Mk2 clocks though.
ok, so there is an L shaped PCB in my cluster, I just need to work out what's wrong with it.
A quick look over with an eye loupe doesn't show up any obvious dry joints, I may swap out the capacitors & see if these are causing the issues, capacitors are the most likely components to have aged over time.
If I cant resolve this does anyone have a MotorMeter branded board I can buy from them please? - I'm assuming that they are not available from aftermarket sources or VW dealerships?
Tony
So I'm definitely after a MotorMeter L shaped circuit board or if anyone knows for sure if a VDO one works for a Mk1 Golf 1.8 GTI then I'd be interested in buying one please.
Tony
