Temperature gauge puzzle
(In Topic #220562)
Goes up to max with red led flashing with cold or warm engine.
As the sender sends a sense indication, that is to allow the Negative side of the cluster, then I suspect the wire or the connection to be flaky. If you have "Plumped" your connector with a piece of electrical tape on the plastic tongue under the mylar, then I would measure between the mylar pin and the Gauge. it isn't unusual for the mylar to get broken. You can feed the gauge direct from the wire side of the connector via an insulated male/female spad connector, to the back of the temp gauge…
Just for giggles, you may want to remove the globs of solder while you have it apart clean the whisker wire and re-solder them with good solder as a Cold solder joint will occasionally test good, but apply some current and it goes south.
I have had both broken traces on my mylar that I had to back feed, 12Vin on the black where the mylar would bend up as I slide the connector on, and I have had broken traces on the 10V stabilizer.
But usually it is the gauge that is the flakiest part of the puzzle.
Those pesky Electrons…..
2001 Zafira 1.8
2001 Zafira 1.8
No, the car is a 1986 - I believe just before the time when the red flashing led was also used for level sensing via some relay trickery.LeeO said
Do you have a relay for the coolant level warning (the red flashing led)? On mine it is relay 43 (but can also be 42) and is in relay plate position 18, row of additional relays on top, far right position. If this is faulty or the relay pins are wet, it will cause the temp guage to go straight to max and led flash. Pull the relay and see what the guage does.
