How do I fix this?
(In Topic #224598)
Steering rack problems
The old ones came off with no problem what so ever and I went to fit the new ones and that's where it's all gone wrong. The new ones (Topran) were tight so I gently wet-n-dried and cleaned the inside of the threads of the first one and screwed it on. I had to use a small wrench but as it was new stuff onto 35 year old stuff, I wasn't surprised
I did the same with the second but it jammed solid and I ended up having to get a long piece of tube on the end of the wrench to get the thing off. The thread on the inside of the track rod is 'clean' so obviously somethings even less right on this one but the problem I now have is that the end of the steering rack thread is also stuffed and nothing is going back on there.
So what can I do, if anything or do I now need to buy a new rack (and another track rod end)?
I see it time and time over, parts are wrong! They need checking with old and new before you fit them.
New rack time.
The track rods should screw on by hand and the locking nut holds them in place.
Topran stuff is not the best quality out there.
Thread file something like this.
https://www.eurocarparts.com/search/538774981?type=shopping&gclid=EAIaIQobChMI78nm_tHw6QIVmKztCh3ghAOiEAQYAyABEgKSQvD_BwE
It’s hard to tell from a picture how good whats left on the steering rack and if you feel it’s unsafe and not going to hold the track rod buy a new rack, you don’t want the track rod to come off the steering rack when going down the motorway or turning hard around a fast bend…..
A new steering rack is under £100 and that’s cheaper than a new car or serious injury.
Many parts suppliers are quite sloppy at labelling/storing stuff and mistakes happen all the time, they just rely on lots of people not bothering to send it back etc or parts don't get around to be fitted. So its quite possible the wrong part (even if it had the right label) was supplied etc.
Anyway I tried the locking nut and not a chance so I'll just have to buy a new rack and another set of track rods. It was one of those "why did I do that??' moments and hind sight is a wonderful thing,.. (I'm not a complete idiot, parts of me are missing
Thanks for all your replies
