Messing with MFA and Eco gauge
is there any easy things to check as it seems my problem maybe intermitant, and my needle gauge works fine going off the scale when i boot it etc, but my shift light doesnt come on.
Karl.
I'm going to make up a prototype loom using big round eyed connectors for the bulbs to sit in, small connectors for the brass bolts, wire and connector blocks. I can't see it being a big task, but it takes time to figure it all out.
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
Here is a picture of the lcd panel, which was looked at:
Oil light repair:
Vaccum sensor repair:
IMG]http://i4.photobucket.com/albums/y138/lhasa/011_11.jpg
This is a rare sight:
Urban
On the motorway:
Outside temp:
I added an extra red led in the middle.
On a more vital issue, are you of the view that the soldering of the three vacuum unit pins is a "fix" that may be generally applied or do you think you happened to get luck in your particular circumstance - guess its a bit of a hard one to answer…
MP
How do you polish out the scratches?lhasa said
That reminds me to polish out the scratches on the perspex tomorrow.
Is there a magic technique?
Michael said
Oh yes. Does it do anything or is it there to fill the blank…
MP
That middle red led is just a blank space and there are no pins that connect to the blue plastic, but I've connected mine to the alarm so flashes when I activate the alarm.
The 3 pins soldered to the vaccum is a good fix as the pins just came away from the blue plastic sheet, but I only did this repair because the connectors just came away from the blue plastic sheet.
IMO- I still think a lot of malfunction issues with the clocks are down to that plastic sheet, because the connectors appear to be crimped on rather than soldered and the copper tracks are very brittle from old age and corrosion. It would, I suppose be a good idea to solder all the connectors to prevent them breaking away. The best solution in the long run would be to a create a fresh loom. I'm in the process of doing this and I'll let you know if it works. I'm looking at modifing XJS connectors so it can go into the old connectors.
Life Member
Any views?
I don't know whats more annoying now, a flashing light on the dash that makes me concerned or a light that should work but rarely does!!
oh and the MFA bulb worked briefly until I went over a speed bump and it went out….. dash out time again!!!
Ta, Dan
