Messing with MFA and Eco gauge
Tell you what - send me spec / photo / drawing … something so I can identify the exact unit and I'll strip down (how many have I got… dunno… 1/2 dozen? something like that) a colection of clusters and see if this is a consistent fault.
MP
If you can test that component, its next to the adjustable capacitor, near to the rear of the lcd.
MP
Do any of these help? Which component matie - assuming they do…(help I mean)
I've only got one panel, are they mk2 gti clocks?
I just wondered if that is a panel from 1600 Gti clocks?
If they are mk1 1800 GTI clocks, but just a different variation, the theory of the resistor goes out the window and its likely to be one of the micro chips.
Time will tell.
I still havn't given up and am working on the idea of clean up the board and checking for any dry joints.
I was just wondering if the 99.9 and -31 problem is unique to the VDO clocks?
Three points:
1. the VW workshop manual states (a) replace G55 unit and if this is not successful (b) replace board - if I recall correctly - just don't have the bandwidth the check this but I am sure my recollection is accurate
2. Yep - you guessed it - the borad is o-b-s-o-l-e-t-e as is the G55 unit
3. Afraid not - this problem is as evident in the Motometer units as the VDO units.
I still think it is the processor but not sure.
Do you have a set of clocks in the vehicle? If so, try this:
Set MPG reading to 0.0 (works on mine). Roll car down a hill - ignition ON engine OFF (ie power to dash) - see if reading stays at 0.0. This will eliminate the input from the hall sender on the speedo as being the problem (vacuum zero).
Set MPG to 0.0, and drive vehicle - and see when MPG setting trips to 99.9. This will confine the error to the vacuum input / G55 unit / circuit board.
MP
Today I removed my fully working Motormeter clocks from my car and fitted just the blue plastic and the lcd panel from the faulty VDO , nothing else and the reading on the outside temp was still -31, after pushing on the blue plastic printed circuit the reading changed to 14. So I'm just wondering if that fragile printed circuit has anything to do with it?
As it happened when I refitted the fully working Motormeter clocks the red oil light failed to come on, but I traced this down to one broken joint on the blue plastic going onto the speedo. I repaired it with some wire and solder.
That blue plastic printed circuit is the pits!
Are we chasing two problems in one thread? (temp + MFA)
Outside temp does not seem to be a common problem ……. but interesting that you had a fault in the blue circuit loom … let me think about this
M
Was thinking of doing this myself to restore my mpg reading on mfa - not too worried about the economy gauge/light, which was always a bit of a pita when working!chudd said
Or use some MK2 clock rears ? I am fitting some in my MK1 20V and have wiring diagrams now for both sorts of clocks . MK2 item is easier to get hold of but does not have the gear change light or vacuum guage .
Also…doesn't the Mk2 have sensible blue mainbeam warning led??? Much better colour - even the early roadtests in the seventies used to commnet on the weird idea of a yellow main beam lamp!
Not sure about the main beam light ? Will let you no .
Waiting for some MK2 clocks to be delivered to see how difficult they will be to fit .
No and no I am afraid - imprinted on the board is 1.8i 82 kw
Another mystery…
M
