GSF reversing switch MFA sucess!!!!!!!!!!!!!!!!!!!!!!:lol:
i suspect the switch
dubburke said
easier said than done, i have found the econ switch but not the reverse switchops:
I am a prat
Would be interested in a more detailed explanation on the wire swap over for the mk2 switch :wink:
Early-1800 said
Are we talking GSF? That?s what they told me, and when it arrives it will be a MKII version. This was before I knew about the trick of swapping the wires in the connector so I took it back. With the standard wiring it won?t work without swapping the wiring? :dontknow: That?s not a problem as it only takes 5-10 mins![]()
No ordered through VW
Member 125 - 2005
I've looked online and they list 2 reverse light switches.
One says '93465' for '82>83 Fuel injection' and its ?3.75, but then there is one that is '93466' and for '5 speed GTI' and this is ?14.50.
Mines and '83 5 speed with econometer, the change light doesn't come on though, and I have no reverse lights.
Cheers,
Gav
Going to tidy up the tackle and go for a blast to see if the change up light works now.
Also put a new clutch and rear main oil seal in this morning so it's been a productive day!
any help me?
I NOW HAVE REVERSE LIGHTS!!!
I NOW DONT GET THE HORRIBLE FLASHING YELLOW LIGHT IN 5TH!!!
MY MFA WORKS!!!
BUT..
the only thing now is the mpg reader on the mfa is still out, its reading at 8mpg at the moment after a short spin.
is there anything else i should try to get that working other thaan change the clocks?
what about disconnecting the battery? will that reset the mfa and kickstart the mpg reading noew the switch is fitted???
