Help needed clipper cutting out
(In Topic #159931)
My clipper has been off the road for the last year. It had been cutting out while driving nearly every ti e I took it out. It has been in and out the garage/ garages and no one seems to know what the cause is as it hasn't cut out on them. I have spent a bit of money but its still not running properly. Somebody said it could be the carburettor,but I wouldn't know where to start llooking any info would be appreciated
Hi,
some information about the model might help: engine type, manual or auto, year, etc…
Generally if your engine is cutting out it is either the ignition or the fuel which needs checking. If it cuts out and won't restart, and there's a strong smell of petrol, it's the ignition, and it it spins over on the starter without firing and with no smell of petrol it's the fuel which is not getting through. Does it run well when running?
Robin
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Though 70s and 80s VWs have this habit of cutting out thanks to things like perished vacuum hoses and carb seals, that would be my first port of call.
Solved the cutting out/not idling issue with my cabby - manual, carb, '84 - by replacing a short single vacuum hose that was perished on the ends and now the car idles and doesn't cut out.
Sorted a similar issue on my old '85 carb manual Polo by replacing the thick rubber seal the carb sits on, before which it would cut out at every road end which drove me up the wall. These issues aren't always easy to find either as they're not always that visible.
It's a 1991 1.8 petrol, auto choke.
When it's running its great, done 130 thousand miles now.
It's been checked for fuel problems, new fuel filter,tank emptied and checked for blockages.
You would be driving along and you knew it was about to cut out not chuddering or jumping just cut out and most of the time it would start instantly on a few occasions you would have to let it sit for a couple of min.
Sometimes it felt you had to keep the revs up especially when coming to a round about as it felt it may cutout.
