Removing description text under my build thread title in Your cars section?
Under the main title of my mk1 build there is some description text which I cannot remove? I assume its left over from before the forum was updated?
It also appears at the top of every new page within that thread, in bold.
Any ideas how to remove it?
Hi pete can
generally you scroll to the bottom of the page find the function button that says edit.
Click on it wait for page to load edit then save
There's a ribbon at the bottom of the page edit over to the right.
I've removed the script for  you if that helps.
Is it the 2012 bit you need removing???
I've removed the 2012 bit but leaving the topic heading.
Brilliant! Thanks for that :thumbs:
I've spent ages trying to work out how to get rid of it O_o
Coolio
