Teves Caliper Query
(In Topic #244076)
As an aside, what is the reason for the raised section on the piston nose ?. I have rotated this to 20 degrees as per the manual but don't see any reason for it as the pad doesn't locate on this in any way. Not unless there is an earlier design of pad that did have some form of anti-rotation profile that aligned with the piston ?.
From the photo, the spring exerts a force on the caliper tending to twist it within the cage and exert a force on the inside pad/disc. Pushing the caliper back against the spring relieves the pressure on the inside pad and the disc rotates freely.
Last edit: by 111Robin
1981 Golf CL 1.3
Regarding the cut-out at the top of piston face at a 20 degree angle, I guess that is intended to counteract uneven wear on the pads caused by the downward drag of the disc when braking
1981 Golf CL 1.3
Last edit: by typ_53b
Looking at the diagram I see how the backside of the spring should push the pads outwards, I don't think mine are like this they are just flat. It's worth trying the correct ones to see if this will help.
1981 Golf CL 1.3
Just a thought, are the pads too thick? According to the manual, there were two different thicknesses - 10 mm and 14 mm, depending on disc and calliper type. For the smaller callipers fitted in conjunction with 10 mm discs, which I think are correct for your 1.3, the pad thickness is stated to be 10 mm.
1981 Golf CL 1.3
1981 Golf CL 1.3
